Old 07-07-2004, 02:38 PM
havicks29's Avatar
havicks29 havicks29 is offline
Send a message via Yahoo to havicks29
Question tps..... ????? what????
ok.. well ive figured out what is wrong with my car. The Throttle Position sensor. ( with the helpful people of autozone). Now my delema is; what the hell is it? what does it do? where does it go and how do i replace it? I checked the price there at autozone and they want 50$ for one. Is that too much? Any one out there replaced one before? please help a hopeless man. yes i am desperate to get my car running right again.
-99 eclipse gs
-420a motor
-auto trans
-arospeed exhaust
-cold air intake
-GSX spoiler
Old 07-07-2004, 05:37 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: tps..... ????? what????
the throttle position sensor is a sensor that is located on the intake manifold/throttle body to tell the ecu what degree the throttle is at so that your timing advance and all that shit will be correct. if your car is a non-turbo, it should be near the back of the intake manifold/throttle body, more to the right side. it's just 2 screws and it pops right off and then you pop the new one back in and the 2 screws go right back in and you should be good to go. as far as the price goes, autozone is pretty good about shit like that so i'd say just buy it and get ur car running again.
Old 07-08-2004, 01:31 PM
havicks29's Avatar
Thumbs up
ok.. thanks for the info. Helps out alot! i appreciate it!
-99 eclipse gs
-420a motor
-auto trans
-arospeed exhaust
-cold air intake
-GSX spoiler
Old 07-08-2004, 05:15 PM
i checked on my eclipse today and the tps is on the throttle body on the very back, it's the top of the 2, there's one a little lower but the tps is the upward one.
Old 07-08-2004, 05:22 PM
havicks29's Avatar
yea checked mine too. i disconnected it and the car still ran. nothing different. so im just assuming that its fucked. because the car ran the same with and without it connected. now all i have to do is go get the damn thing and put it on. thanks for the info again.
-99 eclipse gs
-420a motor
-auto trans
-arospeed exhaust
-cold air intake
-GSX spoiler
Old 03-27-2005, 02:12 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Re: tps..... ????? what????
Can anybody provide any pictures of what this looks like because I am trying to make some sense out of this but I have no idea where or what exactly I am looking for because I am trying to find the TPS. Even holding my hand and step by step scavenger hunt instructions would be great.
Old 03-27-2005, 02:31 AM
kjewer1 kjewer1 is offline
AF - Advisor
The car will run all day without a TPS. Especially a 1g. 2Gs (probably NTs too) also use the TPS for the throttle closed positions switch, so having a bad one can prevent the ECU from going into closed loop idle control. But to say that the car runs fine without it doesnt prove that its bad, in this case.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
