Old 07-07-2004, 02:16 PM
decastroq decastroq is offline
p1400 error how do I fix?
Hello out there!
I have a 3000gt base manual with no mods. Recently the check engine light came on and won't turn off. I get a p1400 error Auxillary Emission Control on an OBD-II computer. After errasing the code the car tends to decrease rpm on idle and turns off. This problem persists until the check engine light comes on again. How do I fix this problem. Thank you.
Old 07-07-2004, 02:54 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
I don't know off the top of my head exactly what you need to do, but this might get you started. For the error code for a mitsubishi I found
Manifold Differential Pressure Sensor Circuit Malfunction
Google came back with these links as talking about the manifold (the second page required a search to find it).
http://www.tomco-inc.com/Catalog/01intro.pdf
http://www.team3s.com/digests/v02n020.htm
Resistance Is Futile (If < 1ohm)
Old 10-31-2005, 12:29 AM
raymann3000 raymann3000 is offline
Re: p1400 error how do I fix?
Did you have any luck fixing this problem?
I am having the exact same issues. Please let me know the outcome.
Old 10-31-2005, 11:27 AM
ChrisGood's Avatar
ChrisGood ChrisGood is offline
let see here p1400
p is for powertrain
then 1 is for manufacturer
4 is for auxillary emissions
and 00 i think that is for dpfe circuit low input
now dpfe is delta (which also means differential) pressure feedback egr
so you are getting a low circuit input from your dpf egr
Now based on the breakdown of the code and what it means i would check your egr. Now I am basing this completely on diagnostic information and the fact that I assume your profile is right that you have a 97, pre 96 no EGR. Also it may be your rear o2 sensor, or even one of the vacuum hoses as these all are part of your auxillary emission control. I know most often EGR codes are due to carbon in you EGR
I can fix anything, if you just tell me how.
White 2006 Chrysler Town & Country
Zurich Pearl White 1993 3000GT VR4
1993 3000GT VR4
Old 11-02-2005, 05:57 PM
The1NamedMarc's Avatar
The1NamedMarc The1NamedMarc is offline
Send a message via AIM to The1NamedMarc
I had that same problem with my 97 VR4. You need a new pressure manifold sensor.
Part # MD305600
It will cost about $100 at rockville mitsubishi with the 3si.org discount.
This was my thread on 3si.org that tells all....
http://www.3si.org/forum/showthread....ighlight=p1400
If you have any other questions, ask away.
[/url]
