Old 07-07-2004, 09:49 AM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
TPS Question....Free Nake Chick Pics For Good Help !! =P
We cant find any way to check how its suposed to be set because - i heard its suposed to be set at .5 but thats the least of my problems right now but needs to be done - cause it does play a role in my buddies camaro ... so if ya know how to check the adjustments an such on the (TPS) Throttle Position Sensor then post something up everything helps us ... thank you
Old 07-07-2004, 12:34 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
use a volt meter and probe the center wire of the connector with the ignition on. it should be around .5v at idle, and around 4.5-5v at wide open. loosen the screws on the tps sensor to move it around to get your desired reading, or you can vary carefully bend the tap with a pair of pliars, but not recomended.
Old 07-07-2004, 12:38 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: TPS Question....Free Nake Chick Pics For Good Help !! =P
I had a TPI L98 Vette and I messed around with all the setting from the stock set 4.4 to 5.1 and the best setting for me turned out to be 4.8 because if I went any higher during wide open throttle responses it would flood the engine and set a code but that was just on my car so higher may work fine on someone else's
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 07-07-2004, 12:43 PM
yeah then i dont need to use a jumper wire with it to check the voltage - thats great i should have everything - so just make sure its set for both of those settings when its closed for idle an then the other when its wide open?
Thanks
Old 07-07-2004, 12:48 PM
4onFloor's Avatar
ya, just set it so you have 1/2-1volt at closed throttle. the tuned ports arent that touchy. you cant really controll what your wot voltage will be, but it should be somewhere between 4.5-5volts
Old 07-07-2004, 12:53 PM
4onFloor's Avatar
oh ya, what they are talking about with the jumper wires is, they want you to completely un-plug the the connector on the tps, and the use jumpers bewteen the connector and the sensor so that you can fit your test probe in there. but i've found that i can fit the probe into the back of the connector so i dont have to unplug anything
Old 07-07-2004, 01:02 PM
Yeah thats what i was tryin to unplug shit cause if its unecessary why do it right... but ya i'll hooked the meter up an set it to .5 an see what happens with it.... thanks man - HAHA an he thats a great photo - how much did those stickers give u ? lol sounds like these ricers around here - all sticker charged cars - i mean i own a twin turbo stealth that dumps 320 hp an 317 lb torque to awd so its not like i got a pussy car there -i have smoke alota shit with it an it handles superb in the turns all wheel steering is a beautiful thing but not if u have to fix it :\
Old 07-07-2004, 01:07 PM
i havnt done anything to it - so its stock an everything is so expensive a clutch is 450-500 thats the stock not even a modded one ... so i am happy with its kick its got fast enough so i just let it stay at what it is for now...
Old 07-09-2004, 12:11 AM
Old 07-09-2004, 11:15 AM
DiabloGT's Avatar
DiabloGT DiabloGT is offline
Banned
wheres the pics?
Old 07-09-2004, 05:48 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
me wanty boobies...
*Better power-to-weight ratio than a C6 corvette*
