Go Back   Automotive Forums Car Chat > Volkswagen > Older Vehicles > Corrado
Old 07-06-2004, 10:58 PM
83Copenhagen 83Copenhagen is offline
Send a message via AIM to 83Copenhagen
Question I need Help - Buying a 1990 corrado
I was just wondering if I should buy this car... It is a yellow 1990 Corado G60 (I think) 4cyl supercharged. It was tastefully modified and is in great condition except the passenger door was banged into by a shopping cart. It's got 65,000 miles and runs great.
Also is there are any things to look for that usually go bad with these cars? and how reliable are these cars?...
Thanks,
Jamie
Old 07-09-2004, 01:07 AM
Dark_Knight_330's Avatar
Dark_Knight_330 Dark_Knight_330 is offline
Send a message via AIM to Dark_Knight_330
yeah i have no idea how old this post is but if you want more than one response i suggest going to www.VWvortex.com a great corrado forum, listen for grinding/disturbing noises coming from the supercharger, if the seller will let you disconnect the boost tube after the g60(supercharger) and see if there is oil in the boost tube... if there is be prepared to spend some money on a supercharger rebuild. other than that check it over like you would any other used car. good luck
1990 Corrado G60 "The Dragon"
Old 11-22-2005, 10:37 AM
Crkbaby Crkbaby is offline
Re: I need Help - Buying a 1990 corrado
Thanks,
No offence but unless you have some good cash coming in or yuo can work on cars they can be a real pain I ll give you a list of parts I have replaced granted you may have good luck who knows
Tranmision Manual
Starter
Alternator
Lots of electrical problems
battery
O2 sensor
wheel bearings
Front Control arm
Temp sensor
Belts
Shift Linkage
Exhaust
Oil presure sensor
hood release cable
Total costs to do yourself about $2000 to pay mechanic $5000-6000
Granted any mechanic that inspects the vehical can find most of these preoblems on a test drive be aware at least in the US the car I pretty rare and parts arnt real easy to find plus people want alot to work on them. Also if it has a factory radio be looking to spend an extra $100-200 on the install wiring is crazy on these.
Old 09-07-2006, 01:54 PM
Corrado2nr Corrado2nr is offline
what kind of price ?
Where is the car located ? If up north CHECK REAL good for rust
