Old 07-06-2004, 08:14 PM
Pathogen Pathogen is offline
How to mod a 3000GT
Hey Guys. Im brand new to the forum, im *sorta* new to car modding (I can do the basics myself, and i know all the mechanical theory..), and im brand new to tryin to set my next car up to be a racer.
Ive got my eye on a pretty 1993 3000GT VR4....
Only car ive ever modded was a Talon, and then a 94 Eclipse (Neither mine, but a friend has a mini-garage set up in his... bigass garage. poor pneumatic crane almost died lifting engine out.
Id like to know how feasible it is, on a budget of a max of $4 on mods alone, to turn my soon-to-be 3000GT into a beast?
What sort of a mods do 3000GTs benifit most from.. what are their major restrictions.. What should i do? I really have my heart set on getting this car, as its so goddamn beautiful, so im praying its also race-worthy.
Old 07-06-2004, 09:12 PM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: How to mod a 3000GT
with 4 bucks huh? well you could prolly go to a hardware store, buy some tubing and make a CAI. Give you like 5 HP more. Wont make it a beast, but might make it feel faster, if not a little louder. . .
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 07-06-2004, 09:17 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
The 3000GT section of this forum is the place to post this, but yea I have one and love it, the only peoblem is the aftermarket is a bit lacking for how good the car is because it dosent enjoy as much fame as the supra or skyline. Go check out the mitsubishi section and click on 3000GT, then search for info on the modding possibities.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 07-06-2004, 09:30 PM
I meant $4k. Sorry.
Wow.. i passed over the Mitsubishi forum like 20 times.. it never clicked in my head to go there.. lol my bad!
Old 07-06-2004, 09:35 PM
Thourun's Avatar
It's ok your new, see you there!
1995 3000GT VR-4
Old 07-07-2004, 12:51 AM
Igovert500's Avatar
blue + red light magnet
Well im sure this will be moved to the correct place, to begin with the 93 vr4 is a beast. It comes with 9-10psi stock, do the free boost mod here:
http://www.stealth316.com/2-freeboost.htm
and you'll be running about 12psi(what the 94-99s ran stock). Then you gut your precats=free
Then you get a LS6 MAFT=200-400, then you get a downpipe=$330, and a boost controller($20-500) and up the boost to 14.5psi. And get a testpipe on ebay for $30. Now you are well over 400hp at the crank, running mid 12s in the 1/4 at least and are technically pretty damn fast and spent less than a grand...now it gets interesting. As thoroun pointed out, there isn't too big of an aftermarket/none at all to get your car running lower than 10 seconds in the 1/4. But with that left over 3 grand, get larger turbos, save a bit more cash and get an air/fuel controller~$350-500, 720cc injectors, and a larger fuel pump. Now you've spent about 5k, and are running 11sec 1/4s. Possibly into the 10s if you are damn amazing(4 or so people have managed it). There are plenty of other mods that you will need to run 10s, most of them simply supporting the boost you are making. The stock clutch wont last much past 400hp at the crank, you'll get spark blowout and have to regap/replace the plugs with copper ones, just to mention a few...damn I wrote alot. So visit the 3000gt forum for more specific questions. And check out this site:
www.3sxperformance.com for parts.
Hope this helps
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-07-2004, 07:18 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
good stuff igovert500, i don't have anything to add
Old 07-07-2004, 03:13 PM
Thourun's Avatar
Wow... wish I could have found a VR-4 for my pricerange, no way to make an SL much better for cheap/free.
1995 3000GT VR-4
Old 07-07-2004, 04:00 PM
Raz_Kaz Raz_Kaz is offline
I want a 3000gt/Stealth
Anyways, my question for the original postee is, do you want to make a track beast or street beast? If your going for the Street beats, it's already done...maybe IHE and your set...but for track, there are numerous things to do, and now you will find the right ppl since its moved to the right forum
Old 07-07-2004, 04:49 PM
xAUTOxRACERx's Avatar
xAUTOxRACERx xAUTOxRACERx is offline
As for track the suspension is a main factor! But for street a few bolt on will do.
Old 07-07-2004, 04:59 PM
Thourun's Avatar
Do you think I could install an exahust myself? Is there welding involved or is it all bolts that hold it togeather?
1995 3000GT VR-4
Old 07-07-2004, 06:48 PM
Igovert500's Avatar
Most aftermarket exhausts are bolt/clamped on. I think with a bit of knowledge and 4 ramps to get the car high enough up, you could manage yourself.
This isn't the most helpful/descriptive page, but it may help a little in giving you an idea of how to support the exhaust and align it and such. Keep in mind, a borla or atr or something of that nature will not need the welding or fabrication that this guy went through.
http://fireman992.tripod.com/exhaust.htm
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
