Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-06-2004, 07:50 PM
cruzin68rs cruzin68rs is offline
Question 2002 wiring diagram for trailer
I was wondering if anybody has a wiring diagram or know what colors to splice into to wire a pop up trailer. Any info would be a big help.
Old 07-09-2004, 04:16 AM
TweakedGM TweakedGM is offline
Re: 2002 wiring diagram for trailer
best way is to use a test light. flash the signal light test it then wire it. all of the wires should be on the inside of your frame on the drivers side at the back
Old 07-09-2004, 08:20 PM
Re: Re: 2002 wiring diagram for trailer
Thank you,
worked like charm. Only other problem now is my right rear tail light does not work when lights are on: directionals, brakes, and back up work fine.
Any thoughts?
Old 07-10-2004, 12:51 AM
on the truck or trailer?
Old 07-10-2004, 08:39 AM
The truck right rear. I checked the fuses and wiring from the light to the connector panel near the spare tire.
Old 07-11-2004, 08:14 PM
with a test light do you have power in the plug
