Old 07-06-2004, 02:07 PM
dssmax's Avatar
dssmax dssmax is offline
MPFI Sensor???
Hi All,
O.K. First off I did try a search but I could not find any info on this sensor or where it hooks up to...
Here is the thing, I can't seem to find any info on this sensor, if it in fact is a sensor.
I'm doing a MPFI swap and would like to know where does this plug in to and what is it called.
I checked out
http://www.fourthgenhatch.com/mpfi.html
and
http://www.binghamtonlife.com/manual/manual.htm
and
http://www.4thgenerationcivic.com/how-to's/mpfi_conversion.htm
And a few others but never came across that sensor...
Thankx,
MAX
Old 07-06-2004, 05:19 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Re: MPFI Sensor???
what intake is that???
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 07-06-2004, 06:06 PM
dssmax's Avatar
Re: MPFI Sensor???
Its off a 89 Si...
Old 07-06-2004, 07:46 PM
91civicDXdude's Avatar
Re: MPFI Sensor???
fast idle valve. you dont have to hook it up.
Old 07-06-2004, 11:14 PM
dssmax's Avatar
Re: MPFI Sensor???
fast idle valve??
Hrmm, what does it do?
Thanks again for your help.
MAX
Old 07-07-2004, 12:56 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: MPFI Sensor???
Controls fast idle. LMAO really thought it controls idle over 750 rpm to 1100 rpm (hmm 1100 or 1200). When under load it idle.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 07-07-2004, 01:01 AM
dssmax's Avatar
Re: MPFI Sensor???
Hey,
B2 on the ECU is the Fast Idle Control Solenoid Valve..
May be I could hook it up and make it work..
Thankx,
MAX
Old 07-07-2004, 01:05 AM
Cjz89civic's Avatar
AF Premium User
Re: MPFI Sensor???
you could but you dont have to.
Old 07-10-2004, 04:13 PM
nsxvtec nsxvtec is offline
Hi,
I don't know where you hail from but if you are driving in seasonal area with low ambient temps and coolant temp below 14 Deg F with engine speed below 1800 RPM, the FICSV activates to increase the air flow rate for fast idle. It gets below 14Deg. F here (TO) so I need it.
Bl/Yel wire connects to #14 fuse and the Bl wire to ECU.
hope this helps
I am going the other way from SI to ZC and will drill and tap ZC manifold for FICSV as no replies to my post so far about this. I have also searched the sites and forums.
Old 07-11-2004, 01:23 AM
audioquattro audioquattro is offline
Re: MPFI Sensor???
200 SQ. FT. OF SHADE!!!!!!!!
hehe
but seriously...you dont need it
FOR SALE
Si 5 sped trans w/ low miles 100.00
SOLD
