Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 07-06-2004, 02:01 PM
timmytot1 timmytot1 is offline
Send a message via AIM to timmytot1 Send a message via MSN to timmytot1 Send a message via Yahoo to timmytot1
Angry 87 Chrysler LaBaron charging system
This car is possessed! I have had the alt changed 4 times, the battery changed 6 times, and the ECU changed 2 times. I am still having an overcharging problem. I can drive it, but I have to have my high beams and blower on. The longer I drive it (20min or more), the more it wants to charge. I then have to add the hazzards in order to keep the charging state at normal. Sometimes it goes to no charge but not often. Any ideas?
Old 07-09-2004, 09:04 PM
slantsixness's Avatar
slantsixness slantsixness is offline
Re: 87 Chrysler LaBaron charging system
You've got something in the wiring full fielding the alternator.
Check the engine harness where the wiring goes to the alternator. probably the hot lead is melted to one of the field leads.
Yoou may have to unwrap most of the engine harness, but it's usually near the alternator.
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 07-12-2004, 10:39 AM
87 Chrysler Labaron
Well, I did find out that the part that was replaced was the Power Module and NOT the computer. I am pissed about that because I was told the computer was replaced. Replaced the EEC module this morning, it took care of the trans problem but not the overcharging problem. There MUST be a short somewhere. Gonna have to do some finding...
