Old 07-06-2004, 12:25 PM
glastron glastron is offline
Unhappy 93 Park Avenue-no kickdown
My 93 PA has similar problems like the others that have posted about the RPM decreasing at 45-60 MPH with the accelerator mashed to the floor. What I do notice is that if I manually downshift the car, it allows the engine to get out of that RPM range, and the tranny to get out of TC lockup and the higher gear. My problem is as well as the others with a similar post is--why does the car not kick down automatically-- could there be a problem with the TPS. This is one of the only sensors that the 4T65-E uses to control itself. Among others are the turbine and output speeds, manifold pressure, and gear selection. The 3800 is a strong engine when it is in the proper gear for required demand. Does anyone have suggestions to this problem?
Old 08-09-2004, 10:10 PM
guerrero79 guerrero79 is offline
no kick down
check fuel sensor below the fuel body it may be getting stuck and causing all the problems. this happened to me
Old 08-24-2004, 03:46 PM
GSteven GSteven is offline
Wink Re: 93 Park Avenue-no kickdown
I have a 94 PAU which does the same thing to a degree. If I actually "floor it" the tranny downshifts as expected. If I am cruising along at 45-60 and gently accelerate the tranny goes into converter lockup and boggs. I assumed (hate that word) that it was just a trait of this particular engine and tranny. My work around is to actually decelerate which shifts the tranny to passing gear then accelerate enough to keep it there.
Not sure if this helps but there ya go....
Steve
no matter where you go, there ya are
