Old 07-06-2004, 10:59 AM
foxylady23 foxylady23 is offline
Honda Coolant
Real quick question... I just got a 98 accord and the manual says to use ONLY HONDA COOLANT. I called the local Auto Zone Etc... and they say that Prestone is fine. I figured it was also. But i want to make sure..Can someone verify this..I have always used Non-honda anti freeze in my past hondas...
thanks, Foxy
Old 07-08-2004, 03:24 PM
avpart3's Avatar
avpart3 avpart3 is offline
Re: Honda Coolant
Thats fine.
AVPART3-
''There's NO Ideas Original, Its Nothing New under the Sun!''
Old 07-08-2004, 04:26 PM
Re: Honda Coolant
Thank U..nobody wanted to go out on a limb on that one...lol
Old 07-08-2004, 09:44 PM
f22burnout f22burnout is offline
Talking
Hey just for your curiosity you can buy these little valves from auto zone or any home store. It's is just a little pipe that has a water hose srew on it. I did this to my accord(It's good to change at least once or twice a year).All you do is cut a coolant line slide it in and put clamps on each side. So then when you fluch the system just hoo the hose up to that screw and open the valve. Makes a lot easier and 50 times quicker. Also any kind of coolant is good. Just don't get the orange $#@!.. It will rust things.
Old 07-08-2004, 09:57 PM
Re: Honda Coolant
F22..tell me about flushing the system. i usually drain the radiator and refill and unloosen a air release screw? on top of the engine. I have not even looked on this 98 accord yet to see if it has one..just what is entailed in a flush and do i need to buy anything or just use water? Thanks, foxy
Old 07-09-2004, 12:09 AM
Well with your flush your supose to empty your system and fill it with regular water and run your engine with just water for a few minutes. Then fill with coolant and water mixture. With the water hose adapter it pushes water through your system breaking things loose etc. Also the nest time you change the coolant you still have that adaptor. Pretty much the whole point is time. Instead of filling up using cups and buckets you have a water hose. Also not to sure about that pressure screw on yours I don't think my 94 has one.
Old 07-09-2004, 12:21 AM
Re: Honda Coolant
F22, thanx 4 the tips...
Old 07-09-2004, 09:44 AM
No prob foxylady
