Old 07-06-2004, 10:16 AM
Langning Langning is offline
How to replace drive belt on 2001 Grand Prix GT
Just replaced the drive belt on my 1996 Cavalier thanks to instruction found on the Cavalier forum (and a low profile rachect from Sears). Now I want to do the belt on my wife's 2001 Grand Prix GT. But I am not sure of which is the belt tensioner as I tried to turn the idler pulley hex bolt on both directions and it didn't yield any slack (I didn't use force as with my cavalier, the belt came off easily).
Is belt tensioner=idler pulley?
what direction should I turn to loose the belt?
BTW, I will use the Goodyear Poly-V gatorback belt from Autozone.
Old 07-06-2004, 11:33 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: How to replace drive belt on 2001 Grand Prix GT
The tensioner pulley will be located on the end of a spring loaded tensioner(like the one on the Cavalier)while the idler pulley will be fixed. The tensioner pulley will have a place for either a rachet or special tool to fit that allows you to move it to loosen or place tension on the belt. To see which direction to move the tensioner look at the way it is pressing on the belt. It should move easily in the direction that will remove tension from the belt. Sorry for the simplistic explanation but that is the only way I know how to describe the precedure.
Old 07-06-2004, 12:28 PM
Re: Re: How to replace drive belt on 2001 Grand Prix GT
So the idler pulley is not the tensioner pully, right?
There are 6 pullies connected by the serpentine belt and according to the routing diagram, they are labeled as water pump, crank, idler, AC, power steering, and alternator. Is the tensioner pulley one of 6 above? Or is belt tensioner somewhere nearby.
Old 07-06-2004, 03:51 PM
carnutcass's Avatar
carnutcass carnutcass is offline
Red line points to the tensioner bolt. Put your wrench, or breaker bar and socket, here and push in the direction of the arrow (toward the fire wall).
Old 07-06-2004, 07:44 PM
Thanks, the picture is nice. So after all, the idler pulley is the tensioner pulley. Just tried with my regular 15mm wrench and it didn't move; will try again with a longer handle. Thanks again.
