Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-06-2004, 08:34 AM
ramzal ramzal is offline
Rear right power window problem
The power window on the rear right side door goes down but does not go up. Right before it had broken down, i had heard a cracking/snapping sound and after that the window wont roll up and keeps falling down. I am a doiturself newbir so could someone let me know what could be the problem and what would be the best way to fix this?
Thanks a lot!
Old 07-06-2004, 02:21 PM
qapmaz qapmaz is offline
Re: Rear right power window problem
If you can hear the window motor running when hitting the switch you probably need a window regulator. This is a common problem especially with the Camry's
Old 03-28-2005, 11:26 AM
sunny05 sunny05 is offline
rear power window
how did you fix the power window problem?? I have the same problem on the left rear side in my camry 93
