Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 07-06-2004, 02:18 AM
greek53's Avatar
greek53 greek53 is offline
94 Lt1 C4 5.7-- Help – Big Problem With Bogging Out – Sputtering – Jerking
1994 CONV C4 LT1 AUTOMATIC ADMIRAL BLUE - WHITE RAG – RARE 1 OF 409 –
Hi, I’m currently experiencing a bogging problem with my vette. The car was put on a SNAP-ON diagnostic computer but didn’t throw any codes. It boggs and sputters along with the occasional mild backfire, it seems to do this more frequent when cold but even after running for a few hours it still has the same problem. I notice it most around 700 to 900 RPM (while turning a corner or accelerating slowly, I’ll try to describe the symptoms the best I can, but seeing is believing so please bear with me. When I first pull away after starting out, the vette will bogg heavily creating a jerking movement, it sounds really hollow and if I continue to press the gas pedal it will not increase in speed, it just seems to hover around the 3000 RPM (at about 20 MPH) mark while sputtering, after a few seconds of this I’ll let up on the gas and drive it at about 15 MPH for a few minuets and it normally shapes up and is driveable. It only has this glitch under load, never in neutral or park. If I hold my foot on the brake and increase the RPM to 1500 or 2000 and let the brake off entirely while mashing the gas there is no problem. As fun as this is, this is not how I want to drive all day and the car deserves better than to be bagged every time it hits the pavement. It also looks like the water pump was leaking at one point in time due to the visible mild rust stains, I went through some bills from work performed on the vette and the previous owner had a new opti installed along with this repair on the water pump leak at 62000 miles or in 2001 (I’m the third owner). Once I noticed this I scheduled the car for plug and wire changes as per dealer advice since there is 85,000 miles on the car, this happens in a few days, but crawling around the corvette pages on the net I found you, “THE EXPERTS” so I imagine you have had the same question posed to you or have heard of such problems, if so I would appreciate your advice. -Lately the car is driving me instead of being driven—
Please reply,
PAUL (stressed out)
I have since decided to do the plugs and wires myself, checked the ohms on the injectors they are all giving a reading of 13.2, changed the fuel filter, tested the EGR, Still the same problem, but the plugs, wires and filter made a noticeable difference in top end power and feel of the car.
Sorry for being naive, but I was just looking at the engine and see that the front driver side has a header bolt missing, I’ll obviously replace it but would that have any effect on the performance.
I'm thinking of taking the opti apart to have a look. I still plan to check out the cats and o2 sensor before doing this, any other ideas??
I need a little direction here, I’m not afraid to work on the vehicle with a little direction.
I may need a little more time to do the work first time round, but it will be carried out to a “T”. I just changed out the plugs and wires and it took me three hours or so to complete, but I’m very confident that it was done correctly, but the initial problem exists.
And yes we had the snap-on diagnostic computer plugged in when I was driving the car to try to get a reading--all symptoms present-- no codes picked up.
Maybe I'll have a GM Dealer hook up their diagnostics as it is specific to the make and model.
Old 10-08-2004, 06:46 PM
Bill_187 Bill_187 is offline
spuddering
I recently had that problem with my '93. I searched everywhere for the problem and finally came to the conclusion that it was the distributer. After replacing my distributer, the car ran fine. The new dest ributer alone was $650, but you can get them refurnished for about $350.
