| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
95 neon help please
i have a 95 neon with 160,000 miles the head gasget was done at 50,000 now after i start the car it runs good but then after 1/2 hr it starts ideling hi and fludders i have changed the map, idel air and cleaned the egr allso i have changed spark plugs,wires,coil pack,and timing belt i tested the thermasat it opened at 212 f so i proped it open but it still dosent help i have run out of options can anyone help thank you
sometime it codes out but this last time it didnt code |
#2 | |
Does it do anything when you drive it? If so, describe that if you can.
I didn't see listed there in the areas checked, but look at the fuel injectors. Could have one bad or going bad. But first I need more info. |
#3 | |
no i havent drove it it bogges out if i give it gas after the 1/2 hr
#4 | |
Re: 95 neon help please
i ran it for 30 min and it started acting up then i shut it down and un hooked the bat for 5 min and restarted it it ran fin i drove it and got it up to 90 miles/hr but after 20 min it bogged out and died once it sounded like a vw bug all the way home i think it is the computer but not sure
#5 | |
Weird. I was going to say upstream O2 or injector, but it's not showing symtoms I am thinking would go with that stuff.
#6 | |
i have unhooked the o2 sensor with no change i have bought a cpu on e-bay for 20.00 i will try that
#7 | |
sounds like fuel pump
#8 | |
whould a fuel pump do that after 30 min becuse before that i can drive it at anyspeed i had it upto 90 the other day
#9 | |
Re: Re: 95 neon help please
The fuel pump will do that,especially if it takes 1/2 hour to do it. You
should have a fuel pump gauge installed and drive for the half hour and see if fuel pressure drops,......good luck |
#10 | |
ok will try that
