is there a way to get turbo from another car and put it in the ka engine for example take a eclipse turbo and put it in the 240??? I would imagine the ecu would be a factor but what if the fuel systems are the same??? cause what I want to do is add turbo without upgrading the fuel systems (5psi) I hear is Ok for the ka engine but I would have to find a turbo that put that out any good ideas??? Remember I do not want to upgrade the fuel system ...O and one more thing how much Hp can I expect with a 5 psi set up?? Im hoping to have 215-230 hp will I need to upgrade then????
Simon R 2001 Silverado W/T 4.3 124,000 |
Re: 5psi turbo
is this possable??
Re: 5psi turbo
Ecu Has Nothing To Do With Turbos..... You Can Put Any Turbo On Any Car, You Just Have To Build A Exhaust Manifold To Suit The Turbo Flange.
IF I AM TYPING IN CAPS (LIKE NOW) I AM SORRY BECAUSE I AM AT WORK (DATA ENTRY) AND I HAVE NO CAPS LOCK BUTTON AND NO WAY TO CHANGE MY UPPER CASE LETTERING. SORRY! EMAIL CONTACT: [email protected] |
Re: 5psi turbo
Build?? or can I get one from somewhere else???
Get it made, or find one that fits.
Re: 5psi turbo
Revhard makes one as does JGS. I just bought one on Ebay for $422 w/shipping. I didn't feel like making one because my stock exhaust manifold was scrapped. But anyways, this should help you out on your way to 5psi
http://www.240sxforums.com/forums/sh...ad.php?t=35258 Keep in mind that this turbo is really gonna limit you pretty low. It isn't really big enough to support a lot more. If you plan on ever going to like 10psi all the time, you should just get a T3/T04 or something. That is also a very budget kit. You may get 200rwhp with a decent exhaust and filter along with a small FMIC. 5psi just isn't gonna give you big numbers especially with a small turbo like that. At least you will spool by like 2K though!
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
Re: 5psi turbo
what did he mean by 50ish??? a fifty hp increase In my opinion is very good how much Hp can I expect with a 5psi set up????
and thanx
Re: 5psi turbo
if your reasons for not upgrading the fuel system is cost, well it ainth that costly, you can use the fuel pump off a 300ZX TT or N/a, I am not sure if you can swap injectors, anyone ever tried to see if 300ZX injectors will work in a 240?????????????????
![]() Ain't this the pretiest motor or what? ![]() Fines are the fee you pay for the privilege of driving as fast as you want
Re: Re: 5psi turbo
i belive the stock 240sx fuel rail can hold up to 350cc injectors b4 upgrading to a bigger fuel rail
1
![]() Shift_BOOST 97 s14 |
Re: Re: 5psi turbo
Re: 5psi turbo
I want to stay as stock as possable just turbo with a 5psi setup how much Hp can I expect???
Re: 5psi turbo
about 208 at the flywheel. Minus driveline loss, at 19%, about 169 at the wheels.
Re: 5psi turbo
169 seems low to me
If you don't wanna put out money, you won't get power, it's not free, man.
Re: 5psi turbo
yea i guess your right...
