Old 07-05-2004, 10:39 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
WTF are these?
I was cleaning my car and i was like what the fuck are these things. 95 GS
Sorry for fuzzy pics my cam was being really gay.
This one is some withe hanging down under my dash. It looks to have some sort of end that can be screwed into somthing.
This is just a pic of under my car that is soaked in brake fluid. It is leaking everywhere and I tend to grind gears more. But the levels of the fluids dont seem to be going down.
This one is in my center concel. It looks like some sort of computer. It is that box towards the bottom.
Now this thing is kinda weird. It is ziptied to the shaft that is connected to my steering wheel.
One more thing when i start my car up it sqeaks like a loose belt then stops. The every few mins it does it again. I also hear a grinding noise when I am ideling there. When I press the clutch in it stops. Also when i am driving or I rev it up i hear a mettalic sound from my engine. My timing?
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 07-05-2004, 11:46 PM
Teazrsnow Teazrsnow is offline
Send a message via AIM to Teazrsnow Send a message via Yahoo to Teazrsnow
Re: WTF are these?
well the first one is just connectors to keep the wires from where it is,sorry bout the fluid, thats the ecu the main car computer, and that might be your tranny goin
Tyler Laabs
2nd Place Drag racing Fwd 3s National Gathering 03[
Old 07-06-2004, 12:04 AM
Re: WTF are these?
I was under the impression that the ecu was the computer under the hood.
Old 07-06-2004, 12:56 AM
gstclips gstclips is offline
Send a message via AIM to gstclips
Re: WTF are these?
the tranny computer is in the consol (thats what jake said it was anyways)...and there is another one under the hood
THE OFFICIAL AF PIMP! - love EclipseRST[Banned]
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 07-06-2004, 06:01 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
that is correct... all N/A eclipses have the ECU under the hood!!! the computer you have under the arm rest is the tranny computer (thats on every eclipse) the turbo cars have the ECU under the cd/tape player...
now for the wire that is attached to the thing you can screw into somthing... that looks like either your clutch sensor or your break sensor... can you start your car without your clutch in? (to check take it out of gear and try to start your car without your foot on the break) and does your car remain in cruise with the clutch in? (to check it go out on the highway and set your cruise... then push the clutch in and see if the cruise shuts off!) and if its for your brakes, push the pedal and see if you have brake lights... easy as that... those are the only three things i can think of!
as for the fluid... check all the connections and see if any are loose or dripping!
as for the grinding... sounds to me like you need a new clutch!
Old 07-06-2004, 08:28 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: WTF are these?
doesnt the clutch use brake fluid. if it does then the leak could be why he grinds gears.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 07-06-2004, 10:33 AM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
Re: WTF are these?
that squeaky belt sound is defntly your belt, check both of them and make sure they r tight if not do so, if it still squeaks CHANGE IT OR THE SAME THING THAT HAPPEND TO ME WILL HAPPEND TO YOU, and its no fun. my belt was doing the same thing and i was being lazy and didnt feel like changing it. well one day it was raining and the belt was load and next thing i know it pops and i lose power sterring and alternator and water pump.
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 07-06-2004, 01:04 PM
Midnight_Outlaw Midnight_Outlaw is offline
Send a message via AIM to Midnight_Outlaw
Auctly Its the computer for the air bags, DO NOT BANG ANY THING ON THAT COMPUTER The air bags will deploy if you hit it hard enough.
1996 Eagle Talon
2.0 non turbo model
hahn race craft turbo kit, 16g
Look at my old car, Pics of the new one coming soon.
http://www.cardomain.com/id/midnight_outlaw
Old 07-06-2004, 04:57 PM
Re: WTF are these?
Could the grinding sound be slave? Also how hard and how much would it be to put in a new clutch and slave. For the clutch I am planing on going turbo some time and dont want to put another one latter if i dont have to.
Old 07-07-2004, 05:58 AM
oxide7 oxide7 is offline
Send a message via AIM to oxide7
Re: Re: WTF are these?
He's Right that computer under the center console is for airbags its not tranny or ECU, the haynes book says it and it even says something about srs on it too.
Old 07-07-2004, 12:51 PM
Re: WTF are these?
I figured out that last one. It is a crossover. I was stripping my car for a total rewire job, and I pulled my door panels and I was like humm those dont look stock pulled out the speakers and they were eclipse's.
So that grinding sound is probly my clutch going out?
How are are they to replace?
Old 07-08-2004, 05:00 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: WTF are these?
i just replaced my belt the a while back and it still squeaks but thats because my water reservoir fell over and the belt rubbed a huge hole in it and now there is coolant all over the pulleys and thats what is making the squeaking so now today i got to take all of them off and clean them up.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-08-2004, 06:04 PM
cweezie cweezie is offline
are you sure that is brake fluid? it looks like it might be oil. yea that is the air bag module If it has yellow harness them it usually is airbags
Old 07-09-2004, 08:39 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Re: WTF are these?
Yea The Belts May Need To Be Changed, But If Not Buy Some Anti-belt Squeaker And Spray It On Your Belts It Should Get Rid Of The Noise For A Good Amount Of Time
