Old 07-05-2004, 10:28 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Code 1 o2 sensor
Well i just did a dx to si swap and fired it up for a 1st time tonight reved it several times turned it off turned it on and then 2 hrs later went out to fire it up and i had a check engine light, checked ecu and its throwing a code 1.. idle is very rough and my air/fuel no longer works. it was all working fine earlier so i dunno if its faulty wiring or the o2 is shot. ur opinions and input will be greatly appreciated
thanks
Dustin
Old 07-05-2004, 10:37 PM
Sicc Si's Avatar
Sicc Si Sicc Si is offline
Send a message via AIM to Sicc Si Send a message via Yahoo to Sicc Si
http://www.geocities.com/motorcity/s...5/ecucode.html
i had the same problem with the idling, but no check engine light... posted the prob, and got some help with it... it was some sensor you had to disconnect and screw it all the way down... cant think of the name right now but ill remember in about 30 minutes if somebody doesnt beat me to it.. GAH !!
Old 07-06-2004, 11:51 AM
Sicc Si's Avatar
FICV
Fast Idle Control Valve
