Old 07-05-2004, 08:36 PM
riceizyummy riceizyummy is offline
Question good or bad to have knock sensor
i was wondering what the advantages and disadvantages were to having a knock sensor or not having one...thanks
Old 07-05-2004, 08:59 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
if it works, the ecm will tailor the spark programme to give maximum advance, if it does not work then it will run in 'limp home' mode and power will be down, emmissions will be up....dogs and cats living together, 4 horsemen of the apocalypse - u name it.
Old 07-06-2004, 02:18 AM
Wolf's Avatar
Wolf Wolf is offline
Send a message via AIM to Wolf
Re: good or bad to have knock sensor
With a knock sensor, if your engine starts getting detonation/preignition, the KS will retard your ignition timing to try to eliminate the pinging. This will lower your power slightly, but it's better than allowing the detonation to continue, which will damage your engine.
If you're racing, disconnect it. For daily driving, it's good to have.
