Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-05-2004, 05:41 PM
ncoling ncoling is offline
ABS light on
My ABS light on my 94 XLT is on, the fuses are ok and the manual says to have the braking systems checked because there is a malfunction. The ABS is supposedly disabled but regular braking is not affected.
Neal
Old 07-21-2004, 07:21 PM
BLUBALZ BLUBALZ is offline
Re: ABS light on
My 94 4.0 Had The Same Problem. It Didn't Affect Breaking, The Light Just Turned On. The Problem Eventually Fixed Itself. I Wouldn't Worry About It.
Old 07-22-2004, 07:46 PM
Car Pal Car Pal is offline
Re: ABS light on
check the connector at the valve to the left of the master cylinder for corrosion.there is a connector behind the passenger side kick panel. it is orange and black.
connect a jumper wire to it and ground it. with the ignition in run the abs light will flash the code.
