Old 07-05-2004, 03:07 PM
awesomemom85 awesomemom85 is offline
Angry windows have a mind of their own
I Have A 99 Camaro And Sometimes The Windows Roll Down(really Slow)and Sometimes They Don't.any Suggestions?also How Can I Reset The Abs Inop?
Old 07-05-2004, 08:05 PM
94CamaroZ28's Avatar
94CamaroZ28 94CamaroZ28 is offline
Send a message via Yahoo to 94CamaroZ28
Re: windows have a mind of their own
the window motor is shot. all you can do is buy a new window motor. if you keep using it it will eventually just get perminently stuck. it happened to me in my '94 Z28 and my buddies '97. GM wanted $300 to fix it
Old 07-06-2004, 01:57 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Agreed.. Window motor is on its way out..
A tip if your changin it yourself, inspect all your tracks and wheels.. Make sure theyre operating properly, and clean and re-grease them..
1991 Camaro Z28
Old 07-06-2004, 09:21 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
i just replaced both of mine, they were doing the same thing each motor is about 40 bucks. its slightly difficult on a third gen, don't know about 4th gens. but i recommend you replace it before it just stops moving, which it will eventually do.
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 07-07-2004, 01:26 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
I just did it on my 94, and it was a real pain in the butt. However, the dealer quoted me at like $350 so it was way worth it to do it myself.
Old 07-08-2004, 10:49 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
how was it a pain in the butt. actually getting to the motors, getting them in, what was difficult about it??
*Better power-to-weight ratio than a C6 corvette*
Old 07-08-2004, 10:51 AM
DiabloGT's Avatar
DiabloGT DiabloGT is offline
Banned
its really easy to do yourself, because it happened on my 95', when you take off the side panels then you just unbolt the motor... then you can take the motor out after you take out the speakers so you can pull it out from that hole, and put it in through the same hole...
Old 07-08-2004, 10:54 AM
what do you mean by side panels. like the interior panels or the door panels on the outside?
Old 07-08-2004, 10:55 AM
DiabloGT's Avatar
Banned
sorry i meant door panels
Old 07-08-2004, 10:59 AM
gotcha...are those just bolted on or are they spot-welded??
Old 07-08-2004, 11:06 AM
DiabloGT's Avatar
Banned
bolted, its really easy, but takes a while so there harder to steal than like civic door panels
Old 07-08-2004, 01:57 PM
haha
Old 07-08-2004, 07:17 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
the abs inop light cant just be turned off, it means your abs isnt working, and it needs to be fixed. the light wont go out till you fix it. if you have fixed it, then you need a tech 2 scanner to clear the codes. or unhook the battery for 30 seconds, that should do it too.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
