Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-05-2004, 01:28 PM
vacaphobia vacaphobia is offline
Angry Rodeo will not start
1998 rodeo, will not start. All connections appear solid, battery seems to be good. When I turn the ignition all I get is a click??? I tried jumping, same thing click. All power options function, lights are good and bright. I washed posts, replaced clamps and it started, after running for a while I shut it off and it would not restart, I wiggled the cables and it started, this happend a couple of times now it will not crank at all. Need help bad. Thanks
Old 07-05-2004, 01:45 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Rodeo will not start
Well since you have good power to lights (headlights) you battery is probably ok. The wiggling of the cables may mean you have a bad body ground.. Follow the neg terminal to where it grounds. Remove it. ruff it up (cable and ground point) with some sandpaper. And reinstall. If it doesn't help I think it would point to the starter (how many miles do you have on it?). When starters start to go bad the do just that. So times they make a click and nothing, and other times they turn right over.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 07-05-2004, 01:51 PM
Re: Re: Rodeo will not start
-Ryan
I cleaned up all connections, and all are bolted in good and tight, do you think the cable wiggle was just a concident (sp), I also turned the sterring wheel one time and it started, could it be just by chance the starter clicked in at the same time? It has over 80,000 miles on it. Are these care generally troublesome? Seems to be a lot of postings about them.
lonnie
Old 07-05-2004, 02:03 PM
Isuzu Guy
Still sounds like a bad start or the connection to the start are dirty. I would assume your battery is only a couple of years old?
As for troublesome? No not really. When folks have trouble they go to the internet and google their problem and this board usually comes up first. Like all cars and trucks, if you don't maintain them you will end up with problems. Also, as it ages all cars have problems, even Honda's and toyota's.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Old 07-05-2004, 04:36 PM
I'll check the connections again. I don't mean to be down on Isuzu, I've just experienced a lot of trouble with this car, and the Trooper I had before it. Thanks for the tips.
Lonnie
Old 05-11-2006, 12:45 AM
jerotum jerotum is offline
-Ryan
hi i got the same problem, i just got a tune-up to my izusu rodeo 1998, in the last few days when i put the key and turn it to start, it doesn't start, i have to try many times to get start, do you think there something wrong with the car or its a normal situation, what do you think i have to do? omar montalvo
Old 05-11-2006, 08:10 AM
Ramblin Fever Ramblin Fever is offline
The Starter. Just went through this myself.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-12-2006, 07:37 AM
Paul A Paul A is offline
Hi,
Had the same problem a couple of months ago.
There is a 10 amp fuse on the starter circuit.
I pulled it,cleaned up the blades on the fuse and so far the problem hasn't come back!
Worth a try!
