Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-05-2004, 11:33 AM
DruBryan DruBryan is offline
Passenger window off track, need help!
Hi all! I have a 94 Jeep Wrangler YJ that has a very annoying problem. The passenger window seems to have come off its track. It is very loose in the door; I can pull it up and push it down, and when I pull it up as high as it will go, it will slide back down into the door. When I try to roll it up with the handle, the handle will not move at all. Is there a way for me to fix it, or do I have to break down and go to an auto shop?
Old 07-05-2004, 04:51 PM
windywinters windywinters is offline
Most small problems like this one can be solved with some basic tools, a repair manual ( Chilton's, Haynes, etc... ), patience and a desire to " do it yourself ". I suggest that you buy a good repar manual from your local auto parts store, study the interior diagram showing the window mechanism and then have at it. Take your time and I'm sure you will see your problem is something obvious that is easily fixed. BUY THE MANUAL ! Learn it, Live it, Fix it yourself.....You can do it !
