Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 01-27-2002, 10:40 PM
G20Rob3's Avatar
G20Rob3 G20Rob3 is offline
JWT Pop Charger Install Question #2
After reading B-Boogie's install page regarding the JWT Pop Charger, I noticed that my POP does not have the little nipple to plug the vaccum hose or air sensor into. Then again, after looking at my airbox, I don't even see a hose or sensor connected to the part that's going to be replaced by the POP Charger. Should I not worry about it, or do you think I got the wrong part from JWT? By the way, I've got a '99 P11.
'99 Nissan Primera GT Turbo
Old 01-28-2002, 07:51 AM
Koojo's Avatar
Koojo Koojo is offline
Send a message via AIM to Koojo
the sensor is located in the pipe that goes from the air box to the fender. im not sure about that other tube that you were talking about. since you dont have a hole for the sensor, you can either leave the original pipe in place and leave the sensor in there, or connect it to the outside of pop charger.
Old 01-28-2002, 07:53 AM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
Re: JWT Pop Charger Install Question #2
Your 99 maybe a little different. If you dont see a vacuum host on the airbox, dont worry about it... I guess
BTW the infamous sensor is on the pipe right next to your battery.
Old 01-28-2002, 11:19 AM
Koojo's Avatar
b-b00gie.....what did you do with your sensor after installing the jwt? how did you connect it?
Do you have any clue is the Stillen pop charger for 2000 have a hole for the sensor, or do u have to custom attach it somehow?
Old 01-28-2002, 11:28 AM
b-b00gie's Avatar
Banned
I'm not sure if it comes with the hole. You dont have to stick it in the filter; just near it. All that sensor does is measure the temp of the air being sucked in.
Old 01-28-2002, 04:37 PM
Koojo's Avatar
So where did you put your sensor?
Old 02-07-2002, 05:13 AM
kheetar's Avatar
kheetar kheetar is offline
hmmm....
This temp. sensor must send the temp. of the intake air to the ECU. I wonder how the ECU uses this information. Could it be that the temperature of the intake air has an effect within the intake manifold(as in changing how much air is pumped into the cylinders or how much fuel is shot into the cylinders by the injectors)?
Hm...I'm gonna have to bust out the Physics book on this one. I'll let everyone know if I come up with anything.
In the meantime, anyone know if the intake air temp. as measured by the sensor actually is actually considered by the ECU's intake programming?
Steve B.
Medical Marijuana Hunger Strike
Old 02-07-2002, 06:48 AM
b-b00gie's Avatar
Banned
It is used by the ECU for something... cut it off and you'll get that nasty light on your dash!
Old 02-07-2002, 09:32 AM
gdalton's Avatar
gdalton gdalton is offline
G20Rob3 the sensor you are talking about is the "boost sensor" I have no idea why they call it that or what it do's but the 99 do's not have one so no need to worry about it.
Kheeter, temperature effects the density of air (the colder the temp the denser the air) the ECU uses the temp readings together with the MAF readings to figure out how much fuel it needs to add to the mix. In other words if the temp sensor is reading 30deg the ECU will put more fuel in then if it where reading 80deg. I hope that helps.
05 Big Blue Stepside
“Somebody kicked my dog Mavis and I’m going to find out just who the hell it was. I’m all messed up on cough syrup right now so just like nevermind.”
JWT Pop Charger question wickedG20 Engine 9 12-21-2001 09:56 PM
FS: K&N Cone Filter for Stillen/JWT Pop Charger NismoPC Classifieds 0 09-25-2001 06:43 PM
used jwt pop charger doodledo824 Classifieds 0 08-10-2001 08:20 PM
How to install a JWT POP Charger b-b00gie General 12 08-08-2001 03:53 PM
2000+ G20 JWT Pop Charger b-b00gie Classifieds 19 08-07-2001 03:48 PM
