Old 07-05-2004, 07:49 AM
pdon pdon is offline
Unhappy serious engine torubles need oppinions
This is gonna be a bit long sorry,
Up until recently i was convinced that i would sell my 4g sedan to a wrecker for $AUD600 and get a Falcon!!! Well as it turns out i cant part with the civic.
Anyway so i took it into where my mum bought it 14 years ago this morning to get some work done. Major service, timing belt, all drive belts, air filter, boot seal (exhaust fumes really turn the chcicks on) and get the Carbies overhauled so this is 1500 thats cool. As it turns out they need to do a compression check and it needs a new water pump and bout 2500 worth of other parts ie sump gasket, brakes, trailing arms & other little thiungs etc so providing the compression is all good i get the carbies done.
its a D15B completley stock so should i get it all fixed up or should i look at gettin another motor, i know that the D15 isnt a performance motor i was gunna do a few little things but being that im on my P's still i dont want to do much in the engine department blah blah blah
I think you get the point oppinions would be appreciated thanks
Old 07-05-2004, 08:18 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
you should find out how much it will cost to fix compared to a better engine. if the cost is close just get the better engine. good luck with all this
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 07-05-2004, 08:28 AM
Re: serious engine torubles need oppinions
thanks mate, its like 1500-2000 to do a head gasket rip-off if u ask me, i really need to get a workshop, but i have to yard.
Does any1 know if anyone hase wokred (is that the correct word) a D15b, i like the engine personally
Old 07-05-2004, 08:48 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
here's some engines you can buy from www.atk-engines.com - you can browse the catalog there, etc. - Prices on far right:
Make | Displ. | Eng.Model |Cyl| Years | Application Information | Part#|Cost + Deposit|
HONDA |2000 |K20A4 |4 | 02-04 |Civic Si, I-Vtec, Chain D | 555 |$ 0 + 0 |
HONDA |2162 |H22A4 |4 | 98-01 |Prelude, V-Tec | 534D |$ 0 + 0 |
HONDA |1000 |ECA1 |3 | 00-01 |Insight | 546 |$ 0 + 240 |
HONDA |1342 |EV/D13A2 |4 | 84-87 |84 Crx, 84-87 Civic Cvcc | 517 |$ 1695 + 175 |
HONDA |1488 |EM |4 | 80-83 |Civic Cvcc 1500, 4-Exhaus | 510 |$ 1399 + 175 |
HONDA |1488 |EW/D15A2 |4 | 84-87 |Civic, Crx, Carbureted, C | 513A |$ 1595 + 175 |
HONDA |1488 |EW/D15A3 |4 | 84-87 |Civic Si,Crx Si,Fuel Inje | 513B |$ 1595 + 175 |
HONDA |1488 |EW/D15A2 |4 | 84-87 |Civic 4wd, Cvcc, Carb | 513C |$ 1595 + 295 |
HONDA |1493 |D15B2 |4 | 88 |Civic, Crx, 92hp, 16-Valv | 518D |$ 1895 + 195 |
HONDA |1493 |D15B6/HF |4 | 88 |Crx Hf, Sohc, 8-Valve, 22 | 518E |$ 1895 + 215 |
HONDA |1493 |D15B1 |4 | 88-91 |Civic, 70 Hp, 16-Valve | 518A |$ 1895 + 195 |
HONDA |1493 |D15B2 |4 | 88-91 |Civic, Crx, 92 Hp, Sohc, | 518B |$ 1795 + 195 |
HONDA |1493 |D15B6 |4 | 88-91 |Crx Hf, 8-Valve, Sohc, No | 518C |$ 1895 + 195 |
HONDA |1493 |D15B7 |4 | 92-95 |Civic, Del Sol, Sohc, 16- | 518F |$ 1895 + 195 |
HONDA |1493 |D15B8 |L4 | 92-95 |Civic, 8-Valve | 518G |$ 1895 + 195 |
HONDA |1590 |D16A6 |4 | 88-91 |Civic & Crx & Wagon 4x4, | 521 |$ 1995 + 0 |
HONDA |1590 |D16B5 |4 | 98-99 |Civic, V-Tec | 550 |$ 0 + 0 |
HONDA |1595 |B16A2 |4 | 96-00 |Del-Sol, Civic Si, V-Tec | 536A |$ 0 + 240 |
HONDA |1600 |D16Z6 |4 | 92-95 |Civic, Del Sol, V-Tec, So | 530 |$ 2295 + 240 |
HONDA |1600 |B16A3 |4 | 93-95 |Del Sol, V-Tec | 536 |$ 2795 + 195 |
HONDA |1600 |D16Y5 |4 | 96-00 |"V-Tec-2", Sohc, 16-Valve | 538 |$ 0 + 240 |
HONDA |1600 |D16Y7 |4 | 96-00 |Sohc, 16-Valve | 538B |$ 2295 + 240 |
HONDA |1600 |D16Y8 |4 | 96-98 |"V-Tec", Sohc, 16-Valve | 538A |$ 2395 + 240 |
HONDA |1600 |D16Y8 |4 | 99-00 |Civic Ex, V-Tec, Sohc | 538C |$ 0 + 240 |
HONDA |1668 |D17A1 |4 | 01-03 |Civic Dx, Civic Lx | 553 |$ 0 + 0 |
HONDA |1668 |D17A7 |4 | 01-03 |Civic Gx (Cng) | 553A |$ 0 + 0 |
HONDA |1668 |D17A2/6 |4 | 01-03 |Civic Hx, Civic Ex | 553B |$ 0 + 0 |
HONDA |1751 |EK1 |4 | 82-83 |82-83 Accord,'82 Prelude, | 508C |$ 1395 + 175 |
HONDA |1751 |EK1 |4 | 82-83 |Accord,Prelude,4-Ex. Port | 508E |$ 1395 + 175 |
HONDA |1829 |ET2/A18A1 |4 | 83-87 |Prelude, Twin Carb, Non-C | 514 |$ 1695 + 175 |
HONDA |1829 |ES2 |4 | 84-85 |Accord Single Carb, Cvcc | 511A |$ 1595 + 0 |
HONDA |1955 |BT/A20A3 |4 | 85-88 |Accord Lxi/Sei, Prelude S | 519 |$ 1795 + 0 |
HONDA |1955 |BS/A20A1 |4 | 86-88 |Accord Dx, Lx, Carb, Non- | 520A |$ 1795 + 195 |
HONDA |1955 |BT/A20A3 |4 | 88-89 |Accord Lxi | 519A |$ 1695 + 195 |
HONDA |1955 |BS/A20A1 |4 | 88-89 |Accord Lx, Dx, | 520 |$ 1795 + 195 |
HONDA |1958 |B20A5 |4 | 88 |Prelude Si, Fuel Injected | 516 |$ 2295 + 195 |
HONDA |1958 |B20A3 |4 | 88-91 |Prelude, Carb., 12-Valve | 515A |$ 2195 + 0 |
HONDA |1958 |B20A5 |4 | 88-91 |Prelude Si, Fuel Injected | 516A |$ 0 + 0 |
The price for an engine (a nice one) is about as much as your repairs - 2000-2500, some with a core charge, etc. If you can put it in yourself that'd be great, but if you get another mechanic to put it in might be a lil costly. You might be able to rebuild your current engine for the same sorta price
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 07-05-2004, 09:17 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
change motors i would mate, get a Si or a ZC and throw in there
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 07-05-2004, 11:36 AM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
yea looks like your spending a grip of money to fix an engine that is more easily replaced then fixed. make sure you do all that work, change the water pump, gaskets, compression, ect to the new engine before you put it in so you have a strong engine with no problems.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 07-06-2004, 09:42 AM
Well the compressions came back ok so, all i need is a sump gasket and a water pump, ill keep the engine now and get a rear discs i think
Old 07-06-2004, 09:43 AM
Civic Jim's Avatar
thats cool, i would maybe get some springs and a filter insstead of rear discs, you have to go quick before you need to slow down fast haha
B16A1 I/H/E
4TH GEN UK SITE
Old 07-06-2004, 09:45 AM
or i could get a fully sik exhaust and a shopping list on the side, i wanna do the discs cos the drums are dead and i wanna stop at any speed not just fast hehe
Old 07-06-2004, 09:48 AM
Civic Jim's Avatar
or you could just change the drum shoes, i very much doubt the drum is scored unless you have been driving it on the metal which aint clever, and the shoes arent expensive anyway, you dont need to uprate to discs on an engine like that mate its not needed at this stage in modding IMO
B16A1 I/H/E
4TH GEN UK SITE
Old 07-06-2004, 09:55 AM
im not being too clear sorry, basically the trailing arms are dead, drums are leaking, and the shoes are knacked, but thats wot u get fro buying a car off ur mum lol, i was gunna do the discs cos all that is stuffed and just thought it would be a bit cheaper in the long run to do it now, i could be wrong however
Old 07-06-2004, 09:56 AM
Civic Jim's Avatar
ah right yeah may as well then mate, sorry i wasnt having a go just coudlnt see the logic to start with lol, is it a hatch or a sedan ? didnt the Si 90-91 crx come with discs over there?
B16A1 I/H/E
4TH GEN UK SITE
Old 07-06-2004, 10:04 AM
ur cool, its a 91GL sedan white and its never borken down, except when from nowhere this giant power poll appeared in the RHS fender... over here i have seen 2 crx's and they were goin real fast, to answer ur question i dunno, in perth there is little intrest in the import market all ford I6's and Holden V8 & 6's
Old 07-06-2004, 10:06 AM
Civic Jim's Avatar
ah right well the crx's where u live came with discs , i take it you got the 1.6-16 ?????? but im not sure if its a straight swap or not, you will have to check that out
B16A1 I/H/E
4TH GEN UK SITE
Old 07-06-2004, 10:09 AM
i was looking at gettin them off a 'teg actually i thought that they would fit i havent really looked into it much yeat my car is still at honda till friday i think or tomorrow either way ill have to part with cash some time soon, ill drive it for a while make sure it dosent do nething strange again
