Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 07-05-2004, 03:48 AM
szicsu szicsu is offline
Services
Hi all,
Could someone tell me what is included in Inspection I and Inspection II ?
thanks
Regards,
szicsu
Old 07-05-2004, 09:22 AM
Antiburn's Avatar
Antiburn Antiburn is offline
Send a message via AIM to Antiburn
Re: Services
Inspecion I is:
-oil change (ncludes new oil filter)
-top off all fluids
-check tire pressure
-check your brakes, all 4
-check over entire car make sure everythings working, lights blinkers seat belts radio air conditioning the whole shabang.
Inspecion II is:
-spark plugs
-gas filter
-oil change (includes new oil filter)
-top off all fluids (anti freeze, washer fluid, ATF,)
-change the micro filter (filter that filters the air your air conditioner sucks in)
-change the air filters for the engine
Now if you get a brake job with an Inspecion you get:
-new brake pads (all 4 or just front 2 which ever you want)
-new rotors (again all 4 or just 2)
-new brake sensors (the sense when the brake pads are to low by scraping on the rotor.)
-the tire pressure is also checked and you can get them balanced. And if the mechanic notices a problem with a tire the service writer willc all you and ask you if you want them changed.
Old 07-10-2004, 03:47 PM
Thanks
Thank you for answer!
Regards,
szicsu
