Old 07-05-2004, 02:09 AM
87TransAmGTA 87TransAmGTA is offline
Send a message via MSN to 87TransAmGTA
Need Help with Fan system on 87 Trans Am GTA
Hey,
My car is over heating because my fans aren't turning on....I have dual fans for my engine and I had to replace a motor because one was burnt out....but they still won't turn on...I think its an electrical problem but not sure how to do that...can anyone help me?
Old 07-06-2004, 01:40 AM
tomminajar's Avatar
tomminajar tomminajar is offline
Re: Need Help with Fan system on 87 Trans Am GTA
This question get asked alot - Could be a relay- Burnt Wire-coolant temp switch-fans could be bad again-
Start the car and turn on the ac - anything ?
Ground out the ALDL (like to get codes) does the fan come on ? Your best bet would be to get a manual (mitchel from library is best) and they will have a flow chart to test them step by step-
GL
Old 07-06-2004, 08:19 AM
tealse tealse is offline
Originally Posted by 87TransAmGTA
Hey,
-------------------------------------------Underneath the car on the pass side engine block is a fan turn on switch .It looks like a CTS Most fan related problems on f-bodys are this switch or fan relays.When you replaced the fan motor did you accidentally pull out one of the fuseible links.or pop a fuse..?? Check out www.thirdgen.org There is alot of helpful info on f-bodys there....Good luck...
