Old 07-05-2004, 01:49 AM
andrewespo's Avatar
andrewespo andrewespo is offline
1988 Mustang 5.0 Question
I recently picked up a 1988 mustang 5.0 5 speed. Only until recently it has been idling high around 2000-2100 rpm. It does this sometimes then i turn the car off and the rpm returns to around 1000. The first time it acted up I pulled the clutch in and the rpm went up to 2500 instead of going down.It will stick at 2000-2100 until i turn the car off. Im curious what the problem could be.
Thank you in advance
-Andrew
Old 07-05-2004, 02:05 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
It could be your throttle cable or the return spring perhaps. You may also wanna take a look at you IAB sensor, although unlikely for a high idle.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-05-2004, 07:46 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: 1988 Mustang 5.0 Question
Sounds like the 20 pin connector on the back of the intake manifold. There was a recall for this this problem, which will use a jumper wire assembly to cure the idle problem.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-06-2004, 06:50 PM
andrewespo's Avatar
I found the problem it was the TPS Sensor. Thx for the input.
Old 07-10-2004, 07:40 PM
andrewespo's Avatar
The TPS sensor is not the problem it started happening again, ill be driving and then when i come to a stop sign or red light ill pull the clutch in and it will rev up to between 2000 and 2500 this will happen without consistence ill shut the car off and it will drive without any problem I changed the TPS sensor, the IAC sensor, reset the EEC-IV,and ajusted everything including the timing belt. TPS. and idle stop screw. I dont know what it could be, I was told the EEC-IV might be screwed up and a new one might be the fix. What do you guys think.
Old 07-10-2004, 07:59 PM
HiFlow5 0's Avatar
Stanger
Re: Re: 1988 Mustang 5.0 Question
Again.
-2013 Ford Flex
-1999 Ford F150
Old 07-10-2004, 08:22 PM
andrewespo's Avatar
sorry. But when you say it will require a jumper wire setup what is that. Also can the 20 pin connector be replaced with a new one?
Old 07-11-2004, 05:55 PM
andrewespo's Avatar
Thx HiFlow5.0 that was the problem i fixed it, now the car is running great.
Old 07-11-2004, 06:37 PM
HiFlow5 0's Avatar
Stanger
Sure.
-2013 Ford Flex
-1999 Ford F150
