Old 07-04-2004, 10:10 PM
JDMrexBoi's Avatar
JDMrexBoi JDMrexBoi is offline
Banned
Exclamation d15b2/93 cx intake manifold?
hey i have a 93 intake manifold and i was wondering if i could put it on my dual port head will the bolts match and will it work period because ive been wanting to conver to mpfi any waze so if is please responde?
Old 07-04-2004, 11:33 PM
Hybrid1990crx's Avatar
Re: d15b2/93 cx intake manifold?
I'm pretty sure the mani will bolt up, but you have to use the 92up throtle body too I believe.
Old 07-05-2004, 01:07 AM
91civicDXdude's Avatar
92-95 CX is exactly the same as 88-91 CRX HF. so basically, you can use the intake manifold and throttle body, but it wont provide much perfromance gain since the assembly is so small in size compared to d16a6/d16z6/d15b7/d16y8/etc.
Old 07-05-2004, 03:16 AM
JDMrexBoi's Avatar
Banned
will i need to use 90 si ,ex injectors and a different distributor because i just wantto go from dual to multipoint injection?
Old 07-05-2004, 11:44 AM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
the mpfi from the cx isnt all that great. it is mpfi so its an upgrade, but i would really consider wheather you really want to do the work to not get all that much gain in performance. i mean its an economy mpfi afterall.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 07-05-2004, 03:36 PM
the wiring is whats important. If you have MPFI, you can easily swap any engine into your car.
If you keep the OBD0 ECU, wh ich you will also need, you need to have OBD0 injectors and MPFI distributor as well to make it work.
Old 07-06-2004, 10:50 PM
JDMrexBoi's Avatar
Banned
thanxk ham bro and the manifold is a d15b7 so the manifold aint small homie plus your right civicDXdude i just want to upgrade to mpfi so im ready for the j-dizzle b16 thanks !
Old 07-07-2004, 08:21 AM
FYI, 92-95 CX is D15B8.
92-95 DX/LX is D15B7
92-95 EX/Si is D16Z6
92-95 VX is D15Z1
Old 07-07-2004, 06:36 PM
JDMrexBoi's Avatar
Banned
yeah mine is a d15b7 but it doesn have the eacv vavle on and its missing the iat in the back? so what should i do bout that?
Old 07-08-2004, 12:31 AM
travagliante's Avatar
travagliante travagliante is offline
Um well you need it and im 95% positive that the dpfi iacv wont work. Youll need to go to a local junkyard and swipe it. lol. I believe that any d-series one will work!
Old 07-08-2004, 07:20 AM
plug the holes where the EACV used to be with JBweld or silicone and wire in a 10w 10ohm resister in the plug. you wont have a cold idle, but the car will run with no CEL. Im sure you could do the same for the IAT.
Or you could just find the parts you need and use them :P
Old 07-10-2004, 02:23 AM
JDMrexBoi's Avatar
Banned
so if i take the eacv and the iat from any d-series it should plug into my stock harness?
Old 07-10-2004, 02:53 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
i've head the OBD0 injectors won't work...well sit in properly...since the manifold is OBD1
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 07-10-2004, 11:54 AM
all honda fuel injectors are 100% identical IN SIZE.
they will work just fine.
Old 07-20-2004, 07:34 PM
JDMrexBoi's Avatar
Banned
so should i get em off the 91 ex or the si crx or the hf?
hit me up on wich would be the best?
