Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 07-04-2004, 09:07 PM
rimfixer rimfixer is offline
Post 1999 corvette water leaking on pass side form ac
Some told me that 97-99 had a problems with the sterring wheel lock battery leaking and the ac water leaks on the pass side. I am looking for a way to fix the problem . The drains are all clear but when the ac is on it leaks .
Old 07-05-2004, 12:39 PM
95corsy 95corsy is offline
Send a message via AIM to 95corsy
Re: 1999 corvette water leaking on pass side form ac
well when any a/c works, it forms condensate (water) that water has to go somewhere....
Old 08-03-2004, 09:05 PM
99suburban2wd1500 99suburban2wd1500 is offline
Having same problem with water condensate leaking on passenger side in 2000 C5 coupe, did you get any other info on possible solution? You also said you check the drains, where are they? Most of my condensate drips outside from the area below the passenger floor board, does yours drip that far aft, too?
