Old 07-04-2004, 08:17 PM
fender5's Avatar
fender5 fender5 is offline
Send a message via AIM to fender5
Question Complete newbie ?
k This is going to make me sound like a complete retard(which i am when it comes to car audio) but if i'm getting two 10' that have a 300 watt rms and 400 watt peak do i need a 300 watt amp, a 600,a 800?
Old 07-04-2004, 08:27 PM
TFFantasy44 TFFantasy44 is offline
Re: Complete newbie ?
600 Watt. Assuming your two 10' subs are 4 Ohm Single Voice Coil, you will need a 600W @ 2ohm amp. What kind of subs are they?
Old 07-05-2004, 11:16 AM
fender5's Avatar
i am looking at either this one here or this one here
So which is better the one with 4ohms or 8ohms since they are the same price. Oh and by the way i put down the wrong watts on my previous post.
One other thing: if it says that a sub needs .60 cubic feet and you are putting two subs in the same enclosure do you just double the needed space?
Old 07-05-2004, 11:41 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
double needed space...
Don't feel like commenting on sub...
www.edesignaudio.com
www.cloudcity.deviantart.com
Old 07-05-2004, 12:34 PM
loismustdie loismustdie is offline
those rockfords aren't that bad, but the ed's haibane suggested are better, don't put two subs in the same enclosure,give each sub its own .60 cubic feet
the aquabats are seriously the best band in the world
Old 07-05-2004, 04:27 PM
fender5's Avatar
Why is having two subs in one box bad?
Old 07-05-2004, 06:45 PM
Haibane's Avatar
you can make 2 enclosures out of the same box..., but what he is saying is put a divider between the subs, don't use same airspace
Old 07-05-2004, 06:52 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I always use the same enclosure ... just too lazy to build a baffle I suppose. but either way, you SHOULD mount the subs physically close together - it causes them to couple their output and increase the efficiency a little
Old 07-05-2004, 10:21 PM
Navy I.C.'s Avatar
Navy I.C. Navy I.C. is offline
they're recommended for small enclosures because smaller volumes of air is easier to compress, that helps with distortion and control issues as far as jumping the magnetic field and keeps the output tight. As far as two separate chambers it's better because if one speaker pop then the enclosure volume ddoubles for the other speaker, and now your risking overdriving your speakers
THE DARKNESS!!!
an African Soup Bone Production...
Old 07-05-2004, 10:55 PM
fender5's Avatar
ok that clarifies it. Now... wat woul be a good amp under 150 for those (either the 4ohms or 8ohms) Brand loyalty means nothing to me just as long as it is the best for my money and it is not a no-name company
Old 07-05-2004, 11:18 PM
Navy I.C.'s Avatar
if you want a dirt cheap amp brand new for under 150 bucks to push that RF 4ohm you can find a power acoustic LT620/2 or get something used off of Ebay
THE DARKNESS!!!
Old 07-05-2004, 11:22 PM
Haibane's Avatar
nine.2 ...
Navy... those subs are not even good in those small of enclosures... Its like audiobahn... you need winisd or some prog to make a real box for it since they are probably way too small boxes
Old 07-05-2004, 11:27 PM
Navy I.C.'s Avatar
yeah you right, those specs read like they really a low/mid for bigger bass componet
THE DARKNESS!!!
Old 07-06-2004, 11:55 PM
Audio Guy
Re: Re: Complete newbie ?
NO .... smaller volumes of air are HARDER to compress, it's why smaller boxes require more power.
Old 07-06-2004, 11:58 PM
Navy I.C.'s Avatar
whoa did I say that wrong...
small sealed = spl
large sealed = sq
right..?
THE DARKNESS!!!
