Old 07-04-2004, 04:21 PM
rodknock rodknock is offline
Send a message via AIM to rodknock
balance shafts
I was just wondering if you could just cut the balance shaft belt and let it ride instead of removing the shafts themselves.
Old 07-04-2004, 04:30 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: balance shafts
Thats fine for the front shaft, in fact thats how I usually do it unless I'm buying a built block. Installing the block off bearings improperly has caused many a crankwalked motor, so I would rather give up the 2 psi oil pressure and just leave the front bshaft in to block the oil holes.
But the rear is driven by the oil pump. You have to remove the front cover/rear bshaft, disassemble, and replace that shaft with the Mirage stubby shaft, part number given in the vfaqs. The one with the oil groove.
Running the rear shaft and not the front will cause some pretty noticealbe vibrations. You need both of them or none of them.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-04-2004, 04:49 PM
thanx for the info
