Old 07-04-2004, 02:46 PM
akadad akadad is offline
96 lumina no start/run
After shutting off my lumina it wouldn't restart. No crank. The radio / accessories shut off when the key is turned to start, but nothing else happens. I checked, and there is voltage to the starter, but not the solenoid. You can jump across the starter and the car will start and run for about 1 second. I replaced the neutral safety switch and ignition switch. Still no dice. When I check the trouble codes the only code I get is for a transmission solenoid that I knew was acting up. I cleared the codes and still nothing. Where next??
Old 07-04-2004, 11:38 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 96 lumina no start/run
what year be this lumina? I would start by checking that the little chip in the key is still intact, and that both contacts on it are clean. If the chip isn't making contact, the key will still turn, but the car may not start.
Old 07-05-2004, 07:52 AM
Decebal Decebal is offline
Check all of the grounds that are connected to the engine block.
Just follow the negative battery cable and see where is leads to, it may go to the frame then the engine but still make sure all contarts are free of oxidation and in good condition.
Hope this helps
Old 08-02-2004, 09:19 PM
dinanmotors dinanmotors is offline
did you find the problem to your lumina
Hi,
I have the same problem on my 97 lumina. Wanted to know if you figured out why it would not start. Please let me know.
Thanks
Old 08-02-2004, 09:50 PM
the~~kidd the~~kidd is offline
ok mine is a slight dif problem, i am gettin all the normal thingds turning on and everything else but no start, I turn the key and it makes a loud click, now i have checked all the lines, new battery, i
Old 08-02-2004, 09:55 PM
Ok i was driving my car the other day and it just died, i was driving in reverse and it just died well i pulled over on the side of the road and tried to start it up again, and it made a click noise a very loud one. Now i went and replaced the battery and checked all the hook ups and everything. I had a frind tell me i might have seized my engine, but when u sieze the egine wouldnt it make a noise of some type, now i think its the starter but i was seeing if newone else has had this happen to them.
Old 08-03-2004, 12:50 AM
tblake's Avatar
In God We Trust
my 1990 lumina, just one morning would not start. Batt was good, and all i got was a click. Friend said to get a hammer and tap on the started, so i did, and it started. Bad spot on the inside of the starter. Replaced it, all is well. Later on sold car, and have since upgraded myself to a 2001 Lumina. Good luck.
Old 08-03-2004, 06:28 PM
just a quick ? it has just two screws right i cant seem to find nemore
Old 08-03-2004, 06:56 PM
SlamminMOfo SlamminMOfo is offline
If you're replacing the starter with an aftermarket, make sure to use the shim if there is one. When you hear cars grinding the starter when starting, it's usually becasue they thought it was ok to omit the shim when replaceing the starter.
Another thing to one of the people that dont get anything when they turn the key... check the coil wire and make sure its connected good.
Old 08-03-2004, 08:34 PM
o yeha i have prolly replaced about a thousand on my ford was just checkin .. thanx for ur help
Old 08-03-2004, 08:36 PM
akadad check the battery
