Old 07-04-2004, 01:26 PM
rx7_obsession rx7_obsession is offline
No Spark
I recently bought a 93 metro, I don't know much about the car but i got it for $50 because it wouldn't start. The distributor rotates, the coil produces a spark and all my fuses seem to be fine. Any idea on what I can check myself before I have to bring it in to the shop..?? The distributor is new so that shouldn't be a problem, there's two wires coming from the distributor that go to the PCM(?) but i have no clue how to check if that's working fine..
Please help!!!!!
Thanks!
Old 07-04-2004, 03:38 PM
Salemetro Salemetro is offline
Re: No Spark
Might start by hooking up a test light to the injector harness....to see if the incector is getting the signal to open. Check Fuel pressure, filter, etc. If all is good and still no fuel from the injector....probably a bad injector. Yes, this would require a bit of know-how...and a Volt-Ohm meter to test, but still beats paying at least $50/hr to a shop. Might start by buying a manual for the car, and reading on how to diagnose/check individual components.
Hope this helps.
-James
Old 07-04-2004, 05:41 PM
Re: No Spark
Thanks for replying! I think I left out something in my original post. There is spark if I test a spark plug directly from the coil, but there is no spark if I test after the distributor. Are the two wires coming out of the distributor what's causing the lack of spark?? Are they tied in with the fuel injection? I think it should be narrowed down to where ever those two wires go...
I'm i'm on the right track or way off please let me know!!
Thanks!
Ryan
Old 07-04-2004, 09:11 PM
barteldt barteldt is offline
Send a message via AIM to barteldt Send a message via Yahoo to barteldt
Re: No Spark
id go get a new cap ive had that problem several times so i keep a spare cap handy now seems to get moisture inside the cap. try a new cap and rotor that did the trick for me each time
