Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 07-04-2004, 01:23 PM
FishaOfMen FishaOfMen is offline
83 Civic Timing Belt Replacement
The timing belt on my '83 Civic 1500 just broke. I've never replaced a timing belt and am looking for some advice. Any answers to the following questions will be very appreciated.
* What's the best way to remove the crankshaft pulley bolt? My father mentioned a way to wedge a braker bar against the frame or ground and then use the power of the starter to get the bolt loose. Because the pulley and bolt move counter-clockwise, I can't figure it out. If I simply stick the braker bar on the bolt head and turn the key, the bolt will be tightened. Anybody know the trick?
* I hear the crankshaft pulley is really hard to pull even when the bolt is removed. What's the best way to remove the crankshaft pulley?
* What other parts should I replace when doing this job?
Old 07-05-2004, 12:35 AM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: 83 Civic Timing Belt Replacement
getting the bolt loose will be the worst of your problems. i would suggest finding someone with an impact wrench. if you can't do that get a long breaker bar, make sure you are in gear and have a friend push on the brake and hope that it doesn’t slip. the bolt is NOT a reverse thread as many assume it is, so don't get yourself all confused. once the bolt is loose the pulley should just slide off with a little encouraging
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
