Old 07-04-2004, 11:38 AM
bclipse bclipse is offline
Underdrive Pulley?
Has anyone ever installed an underdrive pulley in thier GST or GSX. If so is it a good mod and how much power would you get. I know it gave the Breeze some hp when we put it on but would it give the same hp on a turbo motor
95 GS-T
'cause everyone thinks they're right, and nobody thinks that there just might
be more than one road to our final destination
Old 07-04-2004, 01:17 PM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
Re: Underdrive Pulley?
considering that putting a lighweight flywheel and removing the balance shaft made a "tinny" minimal difference, slightly noticeble , i would say that the lightweight pulley is not going to be that big of a mod, besides there is ppl in this forum running low 12's on stock ones.
btw it would be nise if some1 with installed underdrive pulley say how it feels. i would go for the hole set up- cam gears, power str, alternator pulleys
p.s. dude i got the exact same car u do- black with gray bottoms sides 95 GST
Old 07-04-2004, 04:34 PM
kjewer1 kjewer1 is offline
AF - Advisor
Actually poeple run like 8s on the stock pulley. Most poeple dont switch to a non-damped crank pulley, its been shown to cause crankwalk on some cars. With the way our motors like to do it, I cant see taking that risk for 1.873 HP gain...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-04-2004, 10:43 PM
joemathews's Avatar
joemathews joemathews is offline
[quote=95GSXracer]With the way our motors like to do it, I cant see taking that risk for 1.873 HP gain...[quote]
That's 1.921 hp Kevin, get it right.
1996 Eagle Talon
Old 07-05-2004, 12:51 AM
AF - Advisor
Sorry. I dont have actual experience with an underdrive crank pulley, so the numbers may not be exact
Kevin Jewer
Old 07-05-2004, 02:44 PM
98GSX's Avatar
98GSX 98GSX is offline
Send a message via AIM to 98GSX
you know... its cheaper to buy a APC or NAWWWWWWWWWWWSSSSSS sticker and add 10 hp... it reduces crankwalk and improves performance... also you can try the TORNADO.. which is a fan blade taht goes in your intake improving gas mileage and hp! just my
RST Eclipse GST: Here's the thing I am a scammer... thanks for the $225!!!!! <----THAS JAKE
^^^ hehehe
2000 Ford F-250 boostin' 30 psi
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
1991 Geo Storm boostin' 10 psi
1998 Eclipse GSX boostin' 16 psi
1991 Oldsmobile Cutlas Calais
Old 07-05-2004, 04:03 PM
10.5sec92AWDTALON 10.5sec92AWDTALON is offline
There are manufactueres that make dampener underdrive pulleys.
Old 07-06-2004, 12:53 AM
AF - Advisor
I only know of one, and it was like 400 bucks. I think bushur used to offer it back in the day.
Kevin Jewer
