Old 07-04-2004, 04:04 AM
slim720 slim720 is offline
help with custom dome light
ok here's what i want to do. I want to to get a bright blue light as my dome. Unfortunately, if I ever need to use my dome on the road this will be illegal (I've talked to some local cops and they said that any time that they see any blue interior lights they pull that person over). So I'll also need to leave the stock dome in and install a switch in case i need to use the stock dome on the road. Any suggestions on the best way to do this? Can I just buy a generic switch and splice the positive dome light through it in the dome, or will i need to run a whole new set of wires? Thanks for the help fellas (and of course any ladies that would be kind enough to impart their wisdom).
http://dragonsey.net/nikon/car1.JPG
I like rice more than Uncle Ben (bought a honda for the gas mileage)
Old 07-04-2004, 08:34 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
power wise, you should be able to just splice into the existing wiring since you are only gonna be using one of the lights at a time. Mounting is gonna be a different story. Try this ...... just get a replacent lens and color it on the inside with a marker - then keep the orginal if you ever need it. Or just take the lens off if you think it's gonna be a problem.
Old 07-05-2004, 12:21 AM
huflungdung5342's Avatar
huflungdung5342 huflungdung5342 is offline
use blue leds. Just make sure you get the correct resistors on there. And make sure your dome isn't tinted yellowish slightly or is dirty. My friend did the same to all of the interior lights in his car and they were tinted. Ended up being an ugly greenish blue color
Old 07-05-2004, 05:18 PM
Navy I.C.'s Avatar
Navy I.C. Navy I.C. is offline
we use three way switches everyday in the navy.
pos.1-white light
pos.2-off
pos.3-red darkened ship lights
you can pick up the switch from radio shack, just make sure you use a white or clear lense, or no lense at all
THE DARKNESS!!!
an African Soup Bone Production...
