Old 07-04-2004, 01:48 AM
Snake_Man Snake_Man is offline
need some advice on my set up
Hi all just got my new Image Dynamics IDQ10 D2 V2 sub today, also rebuilt my box now its alot smaller how i want and it has a volume of 0.52. Got a couple questions on hooking it all up 2ohm stuff is all new to me.
Right now I have a Rockford Fosgate 501X amp powering every thing. For the sub I have it bridge off the rear 2 channels L+ and R- then on the sub i have one wire to a + on one side then on the - on the other side then another wire connecting the other + and -. Do I have this set up right and does my amp have enough to push the sub or do i need to get a second amp for it
2003 Ford Ranger Edge Supercab Black
Bedliner bugshield Chrome bars class3 tow hitch
Pioneer 4600mp, Pioneer 6x8 240watt 4way in all 4 doors
Rockford Fosgate 501x 1500watt 65x4
Image Dynamics IDQ10 V2D2 sub
Walmart crap box (needs replacing SOON)
Old 07-04-2004, 09:26 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
you have the voice coils on the sub wired in series - I am assuming the sub is a dual 2 ohm model. That's a good way to do it for that fosbreak amp. Since you have 2 channels bridged for the sub, you probably don't want an impedance less than 4 ohms - fosbreaks tend to live up to their nickname when you do that.
Old 07-04-2004, 10:25 AM
Re: need some advice on my set up
so what do i need to do should i not bridge them or what
Old 07-04-2004, 04:25 PM
Im thinking this amp isnt gonna work to well for this sub, probably should have got the duel 4 one.
the power rating are this for the amp
4ohm rms 65x4
2ohm rms 125x4
4ohm bridged 250x2
now i dont know much about duel voice coil subs it says min 4ohm bridged so if i have this sub bridged is it gonna mess up my amp?
Old 07-04-2004, 05:20 PM
Audio Guy
no, you got the right one ........ when you wire the 2 voice coils in series, it becomes a single 4 ohm sub - when you bridge two of the channels on the amp, it can put out as much as 250 watts into that 4 ohm load. You can use the other two channels for the front speakers.
Old 07-04-2004, 09:45 PM
ya i got it working now its just a madder of balancing the fronts with the sub
Old 07-05-2004, 11:35 AM
Audio Guy
that's always the trick, and the balance seems to vary from song to song
