Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-03-2004, 11:43 PM
lienkc lienkc is offline
Unhappy Weird noise from front right wheel.
Recently I can hear some metal rubbing noise from my front right wheel after driving for a while. The noise sounds like something scretching when the wheel rolling. It can be heard while driving but stop when braking. Anyone know what it is?
Old 07-03-2004, 11:53 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
sounds like you need new brakes. And if the screeching has been going on for a while, you need to have your rotors resheened, or replaced as well.
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 07-04-2004, 12:30 AM
Re: Weird noise from front right wheel.
But if it is brake pad, should the noise be louder when braking?
Old 07-04-2004, 08:03 AM
No, because when the pad wears down really far, there is a clip that sticks out and rubs against the rotor. (even if you aren't hitting the pedal). If you have rims that let you see the rotor, take a look at it, and see if you can feel a groove worn into the rotor.
35% Platinum tint
Old 07-04-2004, 11:41 AM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
it's probably your cv boot. you may have a tear in it. nissan can repair it for like $80 but if you let it go for too long you'll need a new axle one day.
check behind that tire, is there grease? if so it's axle grease leaking from your cv boot.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 07-05-2004, 09:16 PM
i3o2Matt's Avatar
i3o2Matt i3o2Matt is offline
Send a message via AIM to i3o2Matt Send a message via Yahoo to i3o2Matt
its most likely the brakes, but you could be right BP2K2...when i had my grand prix, i had the same problem...when i was driving i could hear a lil screeching noise and sometimes when i backed up it was really, really loud, deffinately metal rubbing against metal somewhere...i took the wheel off n looked at the pads...they were like completely gone. when i got my max, it had a torn cv boot, but it had apparently been that way for almost a year, so i just needed a new axle...i couldn't hear any grinding noise or metal rubbing against metal because of it...
Old 07-07-2004, 08:30 PM
dustrman03
Guest
Posts: n/a
is it a clicking noise?
Old 07-07-2004, 09:13 PM
It is some kind of rubing sound. It sounds like "ts-ts-ts..." or "ki-ki-ki.."
Old 07-25-2004, 01:06 AM
ac465 ac465 is offline
i would guess it's the CV boot, cuz my prob is the same as urs. wen i'm driving it makes the tapping noises on the front rite side. wen i was getting an oil change, the mechanic sed th cv boot was messed up. so i'm guessing its the CV boot thats cracked.
Old 07-27-2004, 12:05 PM
dustrman03
Guest
Posts: n/a
ya it may be the constant velocity joint (CV joint) because mine made noises in that area also. i just got it fixed cuz the mechanic found that out when he was changing my fog lamps.
