Old 07-03-2004, 09:37 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
exhausting
anybody know if you can hook up a ported 1g manifold with a ported evo 8 O2 housing and an apexi n1 downpipe on a 2g gsx with a 7 bolt but soon will be swapped for a 6 bolt. and any suggestions to anything that would work better than that set up.
Old 07-03-2004, 09:45 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: exhausting
That will all work. The 1g manifold is a piece though, I would suggest the 2g or EVO3.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-04-2004, 09:14 AM
Re: exhausting
yea i was looking at slowboy and i think i will go with a evo mani stage 2 ported it looked fuckin sweet
Old 07-04-2004, 09:38 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: exhausting
i am really really sure i read somewhere the evo o2 housing & n1 downpipe dont match up!!
DSM geek
Old 07-04-2004, 04:41 PM
AF - Advisor
Re: exhausting
The N1 DP must not have slotted holes then. Actually I should know that, I use Apexi flanges all over my exhaust You will need to slot the holes in the flange.
RRE offers a DP made specifically to mate with the EVO3 O2 housing. Its about 230 bucks, so it may save you some coin too. The angle is also changed slightly so it clears your oil pan. Now that scotsee made me think about it, I would only run the RRE downpipe with the EVO3 O2...
Wait a minute..., What catback are you going to use? If it has a full 3" flange the RRE DP will bolt right up. If it goes back to the shyte stock sized flange (bolts to stock cat) your hosed.
Kevin Jewer
Old 07-04-2004, 05:25 PM
Re: exhausting
i was gonna have a shop customize the rest of my exhaust from the downpipe back. probly use the n1 muffler. but i think the apexi n1 exhaust does have a 3" flange right? also will the evo manifold bolt up to both a 7bolt and 6 bolt because i want to swap this set up over to my 6 bolt when i get it.
Old 07-04-2004, 05:55 PM
Re: exhausting
nevermind i found all that on the RRE site. the apexi n1 does bolt up to the RRE downpipe and the evo mani botls up to the 7 botl and requires a little trim to fit the 6 bolt. anohter question though... what determines whether you need to use an external wastegate or internal??????
Old 07-04-2004, 08:52 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Re: exhausting
Yep, I think all Apexi 3'' catbacks use the same flange, which is what the RRE downpipes use. If you are going to use a custom catback and an N1 muffler, just make sure to buy the flange, which is available from RRE somewhere in the DIY Exhaust sections...
The turbo will make your decision as to which wastegate to use. You can use an internal wastegate on bigger turbos such as 50 trim Garrett's, but an external wastegate is going to give much better boost control on 20g/50 trim turbos and larger. What turbo do you want, and how much boost do you want to run? You almost have to read about all the wastegate quirks, like that you'll get boost creep trying to run low psi on an EVO3 16G with the regular flapper, but if you get the larger flapper you may not be able to run lower boost because it flies open...
Best to be specific with the turbo and make sure someone like Kevin gives it the OK
Old 07-04-2004, 08:56 PM
Re: exhausting
right on joe. im addicted to this forum cuz i learn so much. i want to go with the 20 g. and run around 17 or so psi all the time as a DD. buying hte flange from RRE and doing it custom will be a lot cheaper so im gonan do that. thanks for all the help with this and have a good 4th of july. im gonna blow some shit up right now and pretend its some terrorists. AMErica OWNS THEM
Old 07-04-2004, 08:59 PM
JoeWagon's Avatar
Banned
Re: exhausting
As for the custom stuff, I hope you have looked into buying the mandrel bends from RRE or jcwhitney instead of having them press bend the pipe.
Old 07-06-2004, 12:37 AM
Re: exhausting
so basically ask RRE for eveyrthing i will need from their dp back and just have a custom shop weld it up for me. sounds better than guessing and hoping and im sure RRE would know. thanks agian for the help
Old 07-06-2004, 12:45 AM
AF - Advisor
Re: exhausting
If you search on RKO you can find a list of the parts I used on my exhaust. A 3" apexi flange, a straight section of 3" tubing (5 feet is just enough), 2 3" 45s, and the muffler. Thats it. Its all welded up, with one small crush bent "adjustment."
Kevin Jewer
Old 07-07-2004, 08:56 PM
Re: exhausting
what is RKO? never heard of it. sounds like a plan tho.
Old 07-07-2004, 10:35 PM
AF - Advisor
Re: exhausting
Oh yeah, that would help. Used to be in my sig www.racingknowledge.org. Very slow lately, but there is still some good stuff like this in the archives...
Kevin Jewer
Old 07-09-2004, 08:40 PM
Re: exhausting
right on. by the way how did you (gsxracer) learn so much about dsms? experience? or do you work at a shop or what
