Old 07-03-2004, 04:08 PM
crx hf crx hf is offline
car wont start need help
Well my car has always had trouble starting but today it just wouldnt start.I replaced my coil,rotor,cap and it still wont start.Well it cranks over and it seems like it wants to start.I tried starting it like 15 times know my car doesnt even crank over know theres no power.
Old 07-03-2004, 06:30 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
first things first... Check for spark, gas, and uh.... air. After you determine whether those are not. Move on to things like fuses, main relay, etc. Dont just start replacing random things. That gets costly.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 07-03-2004, 06:32 PM
How do u check for spark?
Old 07-03-2004, 07:33 PM
take a spark plug wire off the valve cover. Stick a long screwdriver in it. Making sure your not touching any metal part of the screwdriver, put the metal part of it a couple mm away from one of the nuts that holds down the valve cover. Have a friend crank the engine and look for sparks to jump from the screwdriver to the nut.
ZC stuff
Old 07-03-2004, 08:13 PM
Well i checked for spark and there isnt any.But is smells like gas when we tried cranking it over
Old 07-03-2004, 08:14 PM
What else can i check for?
Old 07-03-2004, 10:00 PM
hazcc280 hazcc280 is offline
Re: car wont start need help
check the igniter unit in the dizzy...if thats good and still no spark lets pray you dont have my problem
America builds cars like themselves.....Big,Ugly,Heavy and Unreliable
Old 07-04-2004, 12:49 AM
What does the ignitor look like and how do you check it?
Old 07-04-2004, 12:01 PM
Here man, this will help you a lot...
online service manual
Heres the ignitor.
ZC stuff
Old 07-04-2004, 12:08 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Originally Posted by 91civichatch2571
take a spark plug wire off the valve cover. Stick a long screwdriver in it. Making sure your not touching any metal part of the screwdriver, put the metal part of it a couple mm away from one of the nuts that holds down the valve cover. Have a friend crank the engine and look for sparks to jump from the plug wire to the nut.
woah, i have never done it that way.
the best way is to pull out a spark plug and ground it by touching something like your valve cover. crank over and look for spark. no spark = bad ignitor or bad coil.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 07-04-2004, 12:10 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Sounds like the ignition switch itself to me.
As was said before, check to see if there is spark when you crank the engine over... if there is, I'd go ahead and replace the ignition switch itself... $40 for OEM part from AutoZone, and it never hurts to replace anyways.
Honda Enthusiast
Old 07-04-2004, 12:24 PM
I have a brand new igniter sittin around i might as well replace it.Im having trouble taking the old unit out.One of the bolts is stripped and it seems that the bolts arent for a phillips screw driver.
Old 07-04-2004, 12:43 PM
So if i have no spark it has to be either the coil or the igniter correct?
Old 07-04-2004, 01:58 PM
amy@af's Avatar
if you have ignitor laying around and no spark, i would throw it in. if nothing happens then i would hit the coil next
my buddy with a 5th gen just had no spark and it turned into his o2 sensor being bad.
Old 07-04-2004, 04:10 PM
Re: Re: car wont start need help
What?? Thats doesnt make sense... Why did a bad o2 sensor mean no spark?
ZC stuff
