Old 07-03-2004, 02:56 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Unhappy Why does my 2G sound as if it's falling apart?
I love my 97 GS-T Spyder. But oh my god, it lets out more rattles and creaks and groans than Whistler's mother.
I slam the door, the window rattles like crazy and you can swear that the doors are just about to fall off, its almost comical enough to be funny.
Going over bumps etc, the entire car groans and rattles so much, it gets on my nerves. The hinges where the top closes, click and creak virtually every second, while the doors are still clearly the worst offenders, vibrating and making a constant rattling noise.
I could understand if my car was a just like that, but my 1998 Spyder 4G64 did exactly the same things. So does my friend's 96 GS-T and another aquaintence's 97 RS. What the hell is wrong with these damn 2G's? I'm pretty sure that there is a clip of some sort somewhere inside the door assembly that needs to be tightened.
Someone save me before I think about getting a Honda. NOOOOOOOOOOOOOOOOOOOO!!!!!! (The Force is with meeee).
The daily driver. The weekend cruiser. The lazy shop hog.
Old 07-03-2004, 02:59 PM
Str8in Str8in is offline
Banned
Send a message via AIM to Str8in
Re: Why does my 2G sound as if it's falling apart?
wd-40? or some sort of lube (not anal lube thou) did u try that?
Old 07-03-2004, 03:14 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
there is a dsmtuners tech thing on window rattle
Old 07-03-2004, 06:09 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
lolol not anal lube tho,funny shit
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 07-03-2004, 07:59 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
ya i got the window rattle on the drivers side pretty good, but only when it is in between all the way up and all the way down. and whiththe top down it squeaks like crazy. i have heard that baby oil on the seals around the top will help, but i consider it a radio noise... just turn it up and it goes away
as far as all the other squeaks and groans, i don't think it is any more than any other car, i just figure we hear a bunch more because of a lack of proper sound proofing [ie a cloth top, that is mostly in the down position. and it may also be your stock suspension, which you will probably be switching out soon enough
Old 07-03-2004, 08:28 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
http://www.dsmtuners.com/forums/showthread.php?t=57412 put please do not put that foam shit in the doors, that shit is soooo flammable its ridiculous. a spark or to much heat and BOOM.
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
oops i menat but please do not
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 07-03-2004, 08:29 PM
boy i cant F-ing type lol
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 07-04-2004, 12:35 AM
gstclips gstclips is offline
Send a message via AIM to gstclips
yea that foam shit is fun to burn...I agree tho keep it away from your car
THE OFFICIAL AF PIMP! - love EclipseRST[Banned]
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 07-04-2004, 11:36 AM
pr0's Avatar
pr0 pr0 is offline
if your window is rattling its because one of the rails is detached from the window. Take off you door panel to fix it, usually its the side one so its right behind the speaker.
Old 07-04-2004, 07:46 PM
if one of the rails was detached the window wouldnt go up or down, its that stupid plasic little clip all you have to do is pinch it closed more and its all fixed.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 07-05-2004, 12:11 PM
duckydsp's Avatar
duckydsp duckydsp is offline
My window sucks. Ive tightened my window many times and just recently it stopped rolling up and down. It does it for about a cm but stops. I checked and the clip is tightened and is on the rail. What really sucks is the window is all the way up and it a pain in the ass to try to reach the clip.
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 07-06-2004, 01:09 PM
pr0's Avatar
pr0 pr0 is offline
If the horizontal rail is intact the window will roll fine, if the vertical is not it will rumble and stuff. The horizontal is the main rail the vertical is probably not on the window casuing the rattling.
It happened to me. Check the vertical rail.
Old 07-06-2004, 11:14 PM
Shpyder's Avatar
Moderate moderator
gotcha cheers. will work on it tomorrow.
