Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-03-2004, 03:44 PM
attila73 attila73 is offline
Turning Chirp (sound) on for alarm?
Hi..I'm new here and have read for over 2 hours on remotes, but everyone has reprogram issues. I need help in making the alarm activation and deactivation chirp (make sound, horn) because right now all it does is flash the lights. However when I hold down the panic alarm it activates the horn and alarm system. Any help with thsi would be greatly appreciated. I have a 2001 Pontiac Bonneville. My keyless entry remote is
GM/Lear 25695955
FCC ID:KOBLEAR1XT
Canada:3521 102 1718
Please Help.....
Old 07-04-2004, 12:55 AM
randman1's Avatar
randman1 randman1 is offline
Typically, the factory keyless entry does not have any horn honk function (GM) so you can't reprogram the remotes to so. I'm speaking from expreience from the 87-91 and 92-99 body styles as I own both a 90 and alaso 93. Also, I've been in the automotive electronic aftermarket business for some while now.
There are ways to make the horn "chirp" when you lock or unlock the doors either manually or with the keyless entry by using a relay but sometimes this causes unwanted results. For example, if you wired a relay from the lock wire from the key cylinder from the driver's door, it would honk the horn when you pressed the lock button on your remote, but it would also honk the horn when you press the lock switch.
Keep in mind that I don't have the complete wiring schemetic for your generation Bonnie, but this is a typical result. There are aftermarket alarms that are upgrades to your factory keyless entry. They include the chirp upon lock/unlock as well as a shock sensor which your factory anti-theft system does not have.
Old 07-04-2004, 10:37 AM
Smile thank you Randman1
Thank you for explaining that so clearly to me, I appreciate all your help.
I guess I was just used to the aftermarket alarms...been spoiled. Again thank you for your reply. Now I can rest easyer knowing that there is no chirp function
.....Knowledge is power, thanks for helping out.
