Old 07-03-2004, 01:45 PM
JLad10687's Avatar
JLad10687 JLad10687 is offline
Send a message via AIM to JLad10687
Question F250 questions
Are they all supercharged?
Is the only bonus to deisel the price?
What are the pros and cons of deisel?
How many mpg does it get?
I know its not that fast but what is the top speed?
Whats the 0-60 times?
How much torque?
If you can answer any or all of these questions please do so. THank you in advance
2006 VW GTI...
Old 07-03-2004, 02:23 PM
landyacht's Avatar
landyacht landyacht is offline
I'm going to assume you're interested in the NEW trucks, as there's way to many number to go through if it's used.
'04 F250:
None of these trucks are supercharged. That would be aftermarket. The only thing close to a supercharger is the twin turbochargers on the 6.0L diesel.
No. The diesel is more efficient as far as the amount of fuel it consumes, and it has more power then the 6.8L V10. Don't get the 5.4L V8 in these trucks, it's not suitable for ANYTHING.
The pros include more power, ie. tonnes of torque, it's a fast truck. The 6.0L diesel in an F350 crew cab short box single rear whell with the 3.73 limited slip rear axle is faster through the intersection than an '03 Mustang Mach 1 (a 5.4 second 0-60mph car). The 6.0L diesel is the most powerfull diesel Ford has ever used, and is matter to the best transmission in it's class. It's not the most powerfull now, but in '03 it was. It's also very quiet. Not to mention with the 6.0L you have a 7 year 160,000km warranty on the engine.
Cons are of course the smell of diesel. Diesels have much more trouble starting in very cold weather, and you HAVE to let the truck warm up before driving cold weather or not, where as the V10 will start easier and you don't have to let it warm up in the same way as the diesel.
This is hard to tell, as it's not actually rated. In my experience, i sold the exact same F350s to two different guys. EXACTLY the same. One guy was getting 12mpg on the highway with just him the truck and no load, the other guy was getting 22mpg under the same circumstances. Both were measure when cruising at 110km/h with the cruise on for highway driving. It varies, you never know what it'll be in something that big and how you drive i will be a factore aswell.
The speedometers in Canada only go to 140km/h (roughly 95 miles an hour. In something like that, you do NOT want to go fast. The trucks are built to pull something up to a reasonable speed, not to go fast in.
7/8 seconds would be a fair guess. They're not called the G-Force diesels for no good reason! When you step on it, it puts you back in your seat! I don't know when it comes to the 6.8L V10...10 seconds maybe?
How much torque?
6.0L Diesel: 325hp 565lb/ft torque
6.8L V10 Gas: 310hp 410lb/ft torque
Both these engines with automatic transmissions will pull the same amount. Both rated for 12,000lbs or so max when properly equipped.
Hope that's what you wanted to know, to find out more post back or go to www.ford.ca
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 07-04-2004, 12:18 PM
JLad10687's Avatar
Re: F250 questions
Why is the V8, 6.0 better then the V10 6.8?
2006 VW GTI...
Old 07-04-2004, 01:01 PM
JLad10687's Avatar
Re: F250 questions
And, could you go offroading with it?
2006 VW GTI...
Old 07-04-2004, 01:46 PM
FreddieJB86's Avatar
FreddieJB86 FreddieJB86 is offline
Send a message via AIM to FreddieJB86 Send a message via MSN to FreddieJB86 Send a message via Yahoo to FreddieJB86
Re: F250 questions
Why in the hell would you go put that kinda money towards a new truck to take it off roadong get an old beater to have fun in.
I'm just a good ole' boy
"It's not a redneck thing, it's the right thing" - unknown
1987 Ford F150, 300, EFI, 4spd
1979 Chevy K10, 350, 4bbl, auto, full-time 4wd
Old 07-05-2004, 11:57 AM
JLad10687's Avatar
Re: F250 questions
I would want around a 97
2006 VW GTI...
Old 07-05-2004, 12:27 PM
landyacht's Avatar
If you're looking at the '97 model, there was no 6.0L Diesel then, it was a 7.3. I don't think they had the V10 back then either....i think the V10 came out in '99. So if you want to buy a '97 model, buy the 7.3L diesel engine and don't even consider gasline.
The V8 6.0L is better because it's a diesel. The V10 6.8L is a gasoline engine. In big trucks like these, unless you are hell bent on a gasoline engine, buy the diesel always. They have more power then the gasoline engines, stand up better in the long run, and are more efficient iun their consumption.
You can absolutely go offroading in these trucks. Just make sure you do it smart. Get a supercab short box single rear wheel. Lift it, and do your tires, bumpers, winch, roll cage, new seats, safety harness, and everything else. You won't need to do much as far as performance tuning to the motor/tranny cuz it already comes with the power. You just amy want to have a truck shop re-adjust the tranny to handle the bigger tires and the condtions you'll be putting the truck through.
If you're not planning on SERIOUS offroading, then yes it'll be fine. Just make sure you buy a 4X4, and it has decent tires on it. And stay away from mud unless you've got the proper set-up.
Anything else i can answer for you?
Old 07-07-2004, 11:27 AM
JLad10687's Avatar
Re: F250 questions
Landyacht...is that just smoke from your exhaust or does ur Parisienne have a peg leg?
2006 VW GTI...
Old 07-07-2004, 11:46 AM
ModMech's Avatar
ModMech ModMech is offline
Re: F250 questions
BTW, the 6.0L DOES NOT have "dual turbos", it has ONE mounted in the top rear center of the block.
Also, the Lightning IS supercharged, and makes about 280 RWHP.
Old 07-07-2004, 12:52 PM
JLad10687's Avatar
Re: F250 questions
Who said it has dual turbos?...I didnt even know it was turbocharged.
2006 VW GTI...
Old 07-08-2004, 05:01 PM
landyacht's Avatar
Sorry, it is just a single turbo. i dunno what i was thinking there, i know better!
The Lightning is supercharged, as well as some of the newer 1/2 tonne Harley Davidson trucks. But since we're talking about 3/4 tonne trucks i didn't say that since it's not what the questions were about.
That's my old car doing a burnout!
I told you it was turbocharged in my first reply!
