Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-03-2004, 10:24 AM
muskie muskie is offline
start problem/ AC fan speed
Have a 91 ES250 Lexus... 2 problems..when starting the car does nothing but after several tries fires up as normal. Seems like a relay any guesses
2nd problem the A/c controller in the cabin only works at the high end not the low end. Is there a board that needs to be replaced?
Old 07-03-2004, 11:10 AM
300+ 300+ is offline
Re: start problem/ AC fan speed
Typically when cars have only high fan it is the resistors are burnt on the lowers speed. High has no resistor.
My 92 Camry is the same way. If you can get at them they are easy to replace and not usually expensive.
My 81 Celica was very easy, I just twisted them back together. Not appropriate for a Lexus however.
WELLS
BLOWER RESISTOR JA1328 $35.99
This is autozone. Think this is what you want.
Starting problem, don't know.
Old 07-03-2004, 12:05 PM
Re: Re: start problem/ AC fan speed
WELLS
Where are they located?
Old 07-03-2004, 01:51 PM
Usually found behind dash by temp control switches.
2 inch by 2 inch piece screwed to heating cooling system in behind with resistors inside. Resistors look like coiled bare wire. I never did fix my Camry because the dash is a pain. Maybe I'll try again and get back to you.
Old 07-03-2004, 04:13 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Originally Posted by muskie
Have a 91 ES250 Lexus... 2 problems..when starting the car does nothing but after several tries fires up as normal. Seems like a relay any guesses?
Probably your starter solenoid contacts.
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
You can buy the contacts from Toyota
Old 07-06-2004, 10:55 PM
Thanks for making me fix this. The resistor is by your gas pedal. Has blue, green yellow and black wires.
About how I described it before 1 inch by 2 inches 2 screws.
It took me a while to track it down.
Now I will fix the lighter, lights in dash etc since I unecessarily opened it up.
It a pain to get a screwdriver on unless like me you have a racheting one.
Mine just had the solder on the outside broken.
Another free fix like my celica was.
If you need more info drop a message here.
Old 07-13-2004, 04:51 PM
A 90 camry owner found his on the right side of the passenger compartment by the AC duct (recent post about blower and low speed). The 90 and 91 are probably more similar than 91 and 92. Hope you have luck. Let us know.
