Old 07-03-2004, 10:01 AM
c32b1 NSX's Avatar
c32b1 NSX c32b1 NSX is offline
Send a message via AIM to c32b1 NSX Send a message via Yahoo to c32b1 NSX
boost controller
its a noob-like question but what does it do?
Old 07-03-2004, 11:07 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: boost controller
A boost controller is used on turbo systems. At high revs, a turbo can compress more air (air pressure) into the intake manifold than the engine can safely use. The controller bleeds off the excess air , (reducing the pressure) to prevent damage (detonation) to the engine.
Older turbos used a mechanical 'waste gate', just a simple pressure switch. Newer turbos use electronic controllers that keep track of numerous factors in the engine, like revs, engine knock, temperature etc to determine the optimum boost pressure.
