Old 07-03-2004, 08:03 AM
94AccordEX 94AccordEX is offline
Best Replacement Headlight bulb?
Any suggestions for brightest bulb for 94 accord that won't burn too hot? Hate the current OEM bulbs that has shitty illumination.
Old 07-03-2004, 05:23 PM
SenseiAccord SenseiAccord is offline
Re: Best Replacement Headlight bulb?
PIAA or Silvania... or however its spelled.
Old 07-03-2004, 06:22 PM
phoenixitc phoenixitc is offline
PIAA Extreme Whites. Very high on the Kelvin scale, have a slight blue tint, close to HID as you can probably get.
Old 07-04-2004, 11:43 PM
AccordCoupe666 AccordCoupe666 is offline
Send a message via AIM to AccordCoupe666
Silverstar are pretty good
Old 07-05-2004, 07:12 PM
dwilli03 dwilli03 is offline
headlight help
hey ppl i'm a nob at mods and i was wondering if anyone knew what kinda bulbs (white light/xenon) i should get for my 94 accord. i got stock headlights with some clear corners. i need bulbs for it all. so lemme know brand, specific type (9005/9006), brand, watt all that. thanks for yah help
Old 07-05-2004, 10:00 PM
you should get silverstar. they are probably the closest you will get to HID without actually changing your whole headlight assembly. But on my accord, i used APC xenon bulbs but only cause i found them at walmart for only $6 for the pair.
Old 07-06-2004, 12:26 AM
integrasedan integrasedan is offline
becareful if you use higher watts bulbs you might burn the wiring. i use silverstars, for reliability issues. Looks pretty good, better focused light.
Old 07-06-2004, 10:31 PM
Whats the oem headlught bulb wattage for the low & high beams on a 94 accord?
