Old 01-27-2002, 05:58 PM
00GSR 00GSR is offline
Correct Fuses To Reset ECU
For a 2000 Integra GS-R, is the FI E/M (15A) fuse the ECU fuse? Also, should I additionally pull the Hazard (10A) fuse like some people say, or the Radio Back Up (7.5A) fuse like Team Integra's page says?
http://www.team-integra.net/ti/projects/ecu/ecu.asp
Thanks
Old 01-27-2002, 08:12 PM
MAYHEM MAYHEM is offline
Send a message via AIM to MAYHEM
On older hondas you pull the hazzard fuse. So I would pull the hazzard first, wait 5min then pull the ecu fuse while the hazzard is still out, then if you really want put both back in and take off neg batt cable to be sure.
Old 01-27-2002, 08:30 PM
Thanks...I just ended up pulling all 3 fuses (After warming up the car), waiting 10 min, pluged them back in, and started the car to let it stand at idle for another 10 min. It seems to have worked, but if anyone thinks I did it wrong, let me know.
Thanks!
