Old 07-03-2004, 01:42 AM
19k40rocky 19k40rocky is offline
Rear Struts
I got a problem replacing a rear strut on my 89 grand prix. the two bolts at the bottom of the strut refuse to budge. All I can get on it with is an open end wrench because to heads of the bolt are strangely shaped. 2 ends are half mooned and the 2 sides are straight. I have heated the casting with a torch but still nothing helps. Is there a special socket to get this off and if so where can I get it? My parts supplier couldn't find anything like that in his speciality catalogs. Any help/advise would be greatly appreciated!
Old 07-04-2004, 08:09 AM
Dave Walinski Dave Walinski is offline
Re: Rear Struts
Hi,
I have a 1994 Grand Prix that I am changing the struts on now. The bolts on mine are splined that pass through the knuckle. The only way they will come out is to press them somehow. I have only one more bolt to get out, but it will not budge. I am trying to use a C clamp to press it out. Hope this info helps.
Old 07-05-2004, 01:53 AM
Re: Rear Struts
Thanks for the info Dave! I put the nuts back on flush with the end of the bolt and heated the knuckle alittle bit again and rapped it with a 5 pound hammer and out they came. hope you are having better luck with yours. thanks again!
