Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 07-02-2004, 06:29 PM
ottomurray ottomurray is offline
Question PVC and ERG Valve Location 99 Trooper
I'm trying to find the location of both of these since they seem to be much less expensive to install then the shops want to charge.
Old 07-05-2004, 10:14 AM
rodeo02 rodeo02 is offline
EGR valve: Facing the engine, a small can sized solenoid at the rear of the left valve cover. (left rear corner of lower intake manifold) Very easy to get at.
PCV valve: Facing the engine, it's threaded/inserted into the right side valve cover. It's got about a 3/8" rubber (vac) line attached. You may need to pull off the black plastic intake cover first. Another very easy to service item.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 08-18-2004, 12:13 PM
Isuzuoil Isuzuoil is offline
I am looking for the egr valve on my 99 trooper. Isn't it in front of the engine behind the air intake? The rear of the left valve cover is next to the firewall. I suspect we are talking about different things. Could you clarify for me? I too have a oil consumption issue. I have replaced the pcv, and added Techron to the gas, and sea foam to the engine oil.
Old 08-18-2004, 02:07 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: PVC and ERG Valve Location 99 Trooper
http://www.vehicross.info/forums/sho...?threadid=3203
bunch of good photos.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-30-2005, 01:12 PM
trooper99 trooper99 is offline
This link didn't work for me. Can some one post a new one?
Old 01-30-2005, 01:25 PM
Isuzu Guy
http://www.geocities.com/endre_rl/isuzufaq.htm#faq1
http://files.automotiveforums.com/ga...cat=500&page=2
-Ryan
Isuzu Moderator
Car Show Tips
Old 02-01-2005, 05:33 PM
amigo-2k: Thank you for the links and I will try to clean my EGR valve this weekend, I have never clean the EGR valve ( didn't know I need to till now) since I bought it new in 99 (77,000 miles).
