Old 07-02-2004, 06:38 PM
biggunsjk biggunsjk is offline
Send a message via AIM to biggunsjk Send a message via Yahoo to biggunsjk
Question spark plugs......
i have a 2000 gt 3.8 non super i pulled out the stock plugs ans they were the ac platniums i went and installed ac iridiums are these just as good or what else should i use and the correct gap thankyou
Old 07-03-2004, 01:42 AM
BIG-L's Avatar
BIG-L BIG-L is offline
AC changed plugs in the past year and a half,from Platinum to Iridium and the part # is 41-101 and gapped at .060......the funny part of it is on the porcelain it says AC Delco but on the lower part of the plug on the metal it says NGK so the plug is made by NGK for AC Delco.,...............~Larry~
ClubGP Member 6530
Since 2001
Old 02-25-2005, 06:12 PM
GrandPrix1999 GrandPrix1999 is offline
Re: spark plugs......
I have a 99 gt with 66000 miles and I'm planning to change the plugs are those the exact plugs and gap I should use? AC Delco 41-101 at .060
Old 02-25-2005, 07:37 PM
BIG-L's Avatar
Re: Re: spark plugs......
Yep !
Pontiac used to use the AC-Delco 41-921 double platinum plug.About a year or so they switched to the AC-Delco 41-101 which is an Iridium plug.
The AC-Delco 41-101 is for both the GT/GTP.Stock gap is .060
~Larry~
Old 02-26-2005, 12:40 AM
Sweet, now i just have to make sure i know how to do everything it takes to get them out properly
Old 02-26-2005, 11:11 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
When you get to the back ones, as long you know how to swear, you'll have it made.
Old 02-26-2005, 11:22 AM
carnutcass's Avatar
carnutcass carnutcass is offline
A couple of tips on changing spark plugs on the '97-'03 Grand Prix, if I may.
Use spark plug boot removal pliers if you have them.....especially if you've never changed the plugs before. It seems that GM did not use dialectric grease on them when they built our engines. Consequently, the boots have a tendancy to "cook" to the plugs. Make sure you slobber some dialectric grease on the porcelain part of your new plugs as you reassemble.
Reuse the factory heat sheilds that came with the car.....unless of course you're using specialty wires that are made to withstand higher temps, like the MSD Super Conductors.
Remove your engine cover support bracket from the rear of the engine. This will allow you to change the rear (right bank) plugs without having to rock the engine forward. Reinstal this bracket if you intend to use your engine cover. Leave it off if you don't....you'll save a couple pounds.
Use a universal joint and short extension for the #6 plug. The O2 sensor is in the way and you will end up pissed if you don't use a universal joint. Trust me on this!
Kneel on the radiator supprting cross member to change the rear (right bank) plugs. This will make it easier to reach them and make you less likely to dent or scratch a fender.
You may want to make sure you do this procedure while parts stores are open. If you break a plug wire....and it can happen, no matter how many years you've been working on cars........you'll be dead in the water! Better yet, go ahead and plan to change plug wires at the same time. Our wires tend to remain servicable for 100,000+ miles but I can tell you from personal experience that you can damage a wire that has as little as 40,000 miles on it. I know this!
Not to make this a sales pitch but, if you are interested in replacing your wires but are a little low on scratch, I have a NEW set I can sell you. These are the Ultra Spark wires AutoZone sells for $45. I had to buy them because I broke my #1 wire. Only the number one wire was used...and it was only used for about 2000 miles. $20+freight and their yours. I also have a set of the factory plug wire boot heat shields if you need them as well.
Old 03-01-2005, 12:32 AM
njsp njsp is offline
I have a 95 Grand Prix with 135,000 that I purchased last year from a guy that really took good care of it and it runs great. My question is I purchased a set of Bosch Platinum 2's and Bosch wire set and installed them 3 days ago. I have since noticed it "bogging" around 3000 once or twice. I have been reading posts about people not liking the Bosch plugs and that AC Delco OEM plugs should be used but which ones should I switch the Bosch out for? The AC Delco Standard plug, the Platinum plug, or the Rapidfire plug? Thanks!
Old 03-01-2005, 12:39 AM
Re: Re: Re: spark plugs......
Originally Posted by BIG-L
Yep !
~Larry~
Read this one again.
Jim
Old 03-01-2005, 11:03 AM
BIG-L's Avatar
Jim,he has a 1995 GP,which use's different plugs then 97/03
Not sure if you have the 1995 3.4 or 3.1.But id stick with a Platinum plug.
3.4 AC-Delco 41-932 @ .060
3.1 AC-Delco 41-908 @ .060
Old 03-01-2005, 11:19 AM
jimmytroanoke jimmytroanoke is offline
What the he## has happened to Bosch. They used to be the cats ass in just about everything they made. My area is blanketed with Advance auto stores who really push them, but I have learned the hard way not to touch them. In my 2 ford modular V8s the bosch plugs (Double Platinum) ran less than 20k miles before gunking up. The OEM's went 75k plus. Replaced with OEM from dealer and problem solved. I won't even waste my time with anything else. I have heard the same deal about their O2 sensors.
2001 Grand Prix SE 3.1 - Someone elses problem now!
95 Grand Marquis - Will outlive all of them!
97 F-150
2004 Toyota Avalon
Old 03-01-2005, 12:12 PM
BIG-L's Avatar
With the old Bosch line (standard Super Plugs) they where fine,but then they came out with plugs that are not engine specific,like Platinum,Platinum2,Platinum+4.Buy the meaning of engine specific,they are not the correct heat range for most motors and seem to foul out very fast.Bosch may only make about 20 different plugs,in say the Platinum series and what fits our cars,may also fit 100 different makes and models of cars.That means for the retailer,it takes up less space on the shelf and more room for other parts.
Years ago (1978) Accel use to buy there plugs from Bosch and use the Super plug and put there name on them.Now Accel buys there plugs from Nippon Denso or now they are Denso.ND plugs have been around for year's and had a design called a U-Groove plug.Now for the past 20 years Accel has been using the same U-Groove plug from ND.Just a little history on the Accel plug/Bosch/ND
Denso U-Groove plug
ACCEL U-Groove performance spark plugs
Old 06-18-2005, 01:34 AM
georoid georoid is offline
I have 2000 Grand Prix SE 3.1
Can I use Iridium spark plug?
I checked at AD Delco website and they recommeded to use platinum plug or rapid fire plug. And I found that iridium plug is recommended for 3.8 engines.
Thanks in advance
